Deutz 385 planter
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Topic: Deutz 385 planter
    Posted: 11 Apr 2024 at 5:05am
In the next few days I will be listing the following spare parts for Deutz-Allis 385 and Landoll 4400 planters on the Facebook AGCO and Allis-Chalmers free auction page. Please share or tag anyone you know using these planters. Some parts will also fit the older Allis-Chalmers planters.  I’m located near Postville, Iowa 52162 and buyer will be responsible for shipping or local pickup.  Thanks!
1. Used 300 series population monitor with blower control and power supply boxes
2. Two used seed hoppers
3. New clutch release cable
4. New speed sensor
5. New seed tube sensor
6. Seed meter housing with water pump bearing
7. New gauge wheel tire
8. Lot of three soybean air plates part 70581252
9. Lot of seven medium round and flat corn air plates 70585807
10. Lot of six large round and flat corn air plates 70586141
11. Lot of six small popcorn/sunflower air plates 70584901
12. Box of miscellaneous used blower parts
Edited by Russ-neia - 11 Apr 2024 at 8:20pm
The innovators offer what others will imitate.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2024 at 6:03am
Just a suggestion, but you might have better luck posting in the Classified section of this forum.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2024 at 6:24am
Would you happen to have seed wipers 71510366 (air cut off pad)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2024 at 8:21pm
No, I do not.  Have you tried getting them from Landoll?
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2024 at 9:48pm
That's the next step. Thanks
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2024 at 1:50pm
Landoll has them. $45 a piece, its high but new pad will last for a lot of acres
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
WdIndy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WdIndy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 2:32pm
I see this post is pretty old but checking to see if you still have those planter parts available.
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 5:45pm
WDindy, what all are you looking for?
This page was generated in 0.157 seconds.
