d14 idle
mhbier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhbier Quote  Post ReplyReply Direct Link To This Post Topic: d14 idle
    Posted: 04 Apr 2024 at 10:58am
I rebuilt the carburetor on my d14 and now it only runs good with the choke half open. What did I do wrong? The idle screw makes no difference.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 11:34am
Having to leave the choke on is a classic symptom of having a fuel restriction somewhere.  Not enough fuel, so to get the ratio right, it has to cut the air.  I'd look at the jets first, then go backwards through the fuel passages.  Did you replace the jets?
If it's not that, less likely, it could have an air leak or the float is way off.
If it's a Schebler, the idle screw affects the throttle butterfly so with the choke on, it won't have much effect until the choke is off.
1951 B
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 12:05pm
The last kit we got to rebuild the MS - the inlet hole the needle goes in was about half the size it should have been - compared to the old seat. We had to drill out the hole. Having said that , as stated you are not getting enough fuel of course - does it idle correctly? That is about the only thing the idle adjustment does.  The main load screw - if it has one - the oem carbs did - will flood the engine when screwed out too far and stall it when scewed in. After warmup and the initital setting of 2.5 turns out - turn the screw in til rpm drops then back to where it sounds great - then an extra 1/4 turn out. The main load passage ways/jets and needle seat are the # issue .
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 12:52pm
It's probably like the others said, but start at the beginning. Is there good flow coming out of the tank?
