carburetor
mhbier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhbier Quote  Post ReplyReply Direct Link To This Post Topic: carburetor
    Posted: 02 Apr 2024 at 5:35pm
I rebuilt the carb on my d14 and now it won't idle lower than about 700. Any idea what is going on? The idle screw doesn't seem to make a difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 5:47pm
does the carburetor arm come all the way back AGAINST the screw... or is the arm dragging the side of the engine block ?
Did you bottom out the adjusting screws and back out 1.5 turns to start ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 5:48pm
Throttle plate disc not centered in the bore if what you say is true. Loosen low idle speed screw three turns, loosen two screws holding the throttle plate, force the throttle closed to center the disc and re-tighten the screws.
This page was generated in 0.471 seconds.
