Interesting rocks |
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2309 |
Topic: Interesting rocksPosted: 29 Mar 2024 at 10:23pm |
Found these "A" typical rocks while digging out a spring.
Nerver saw these before on our farm. Just this one time in a recent exivation of a spring. Funny thing, where there is clay formations water bubbles up out of the ground. I am capturing this water and plan to make spring development watering troughs. |
Macon Rounds
Posted: 29 Mar 2024 at 10:28pm |
![]() ![]() ![]() When the rocks are chiped or broken. The inside is a darker gray that seems to be encapsulated in a lighter brown coating. I would assume a volcanic revolution but NO where else have I seen these rocks. What's your thoughts ? |
wjohn
Posted: 29 Mar 2024 at 11:16pm |
I am not familiar with the geology in your area, but that looks a lot like limestone.
allisorange
Joined: 27 Mar 2010 Location: perkins, michig Points: 381 |
Posted: 30 Mar 2024 at 8:04am |
Looks like limestone to me also. Have lots of it in are area. J.Carlson
Kenny L.
Posted: 30 Mar 2024 at 8:21am |
It's limestone and with not seeing it in person I'm guessing it is what we call cap rock in Iowa.
Ky.Allis
Joined: 31 Jan 2010 Location: Kentucky Points: 1046 |
Posted: 30 Mar 2024 at 12:58pm |
We always called them sex stones if we had to pick them up out of a field.
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 30 Mar 2024 at 1:13pm |
Any evidence of the CCC doing any work on your property back in the 1930’s? They may have hauled in that rock, buried it in your ravines.
Brian G. NY
Posted: 30 Mar 2024 at 4:00pm |
Is the dark part very hard with a smooth glasslike surface? If so, it may be chirt or flint.
You may be able to strike it with a piece of steel and get sparks. The better quality stuff was used to make arrow heads and other tools by the ancients.
I ran across a vein of it when a heavy rain washed out an old log road on my property here in the Western Catskills of New York. |
Macon Rounds
Posted: 30 Mar 2024 at 7:35pm |
We don't have limestone in our area.....
Not that the good lord didn't drop some on our farm but I will investigate more..... |
Brian G. NY
Posted: 30 Mar 2024 at 9:21pm |
And.....you might want to "investigate" chirt as well. J M H O
jvin248
Posted: 30 Mar 2024 at 10:16pm |
. Looks like common limestone. If it's flint/chert it will break and feel like oily glass. You could sell flint/chert online. I paid a mint for some recently (long hobby since a kid). This is a great channel. He has a video on finding rocks to start with. .
Edited by jvin248 - 30 Mar 2024 at 10:17pm |
Brian G. NY
Posted: 31 Mar 2024 at 11:42am |
The first picture is your rock, the other two are mine. I think you can see some similarity although the dark portion on mine appears smoother. On mine the dark part is very hard and very smooth yet similar in color to yours. The Chert/Flint is sort of encapsulated in the softer brown material. When my brother and I ran across these when we were kids we called them dinosaur bones because the brown part sorta has the texture and color of old bones. As I said, a few years ago I found a "vein" of this stuff after a flood washed out one of my old log roads. ![]()
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6126 |
Posted: 31 Mar 2024 at 6:52pm |
Rocks are formed as a result of materials being compressed together, and chemically binding from any number of circumstances. There's three basic types of rocks: Sedimentary, Igneous, Metamorphic Sedimentary are just as they sound- the result of water and wind distributing surface accumulation of material, then pressure and chemistry binding the soil contents together. The indicator of a sedimentary rock, is layeriing, and the general ease at which it can be broken into layers and dust. Limestone and sandstone are the most common examples, formed from clay. Chirt is a type of limestone where biological organisms's decay leaves behind exoskeletal remains that form a high content of particular patterns of metals like calcium, phosphorus, pottasium, silica, iron.... Igneious rocks are magmatic- formed by intense heat and pressure... and usually when this happens, there's lots of things that simply don't appear because, at that temp and pressure, the other stuff simply cannot stick around... it gets 'boiled out. Igneous includes more iron and silica... with smaller components of sedimentary source to form basalt, granite, mica and quartz, flint, feldspar... and if it happens to be infused with gasses that expand as it freezes, it'll form abrasive crystalline structures like pumice, ash, and stuff. Metamorphic is what you get when sedimentary rock is subjected to high enough pressure and temperature to melt, but not flow. It gets patterns and layers, but it doesn't easily break apart, because it has interfused itself. Slate, marble and quartzite are the metamorphics most people come across regularly.
Brian G. NY
Posted: 31 Mar 2024 at 9:03pm |
So Dave, in your comsidered opinion, which type of rocks do Macon and I have?
Macon Rounds
Posted: 01 Apr 2024 at 11:14am |
Here are a few better photos of mine.
Brian G. NY
Posted: 01 Apr 2024 at 3:32pm |
Your closeup pictures make it clear your rocks are different. They do not have the smooth glasslikefeatures that mine have.
Don't know what they could be.
Macon Rounds
Posted: 01 Apr 2024 at 6:09pm |
Found 2 more larger ones today in another spring about 100 yards away from current spring development....
These rocks always seem to be around gray soupy clay. . Google lens cannot identify them . ![]() Edited by Macon Rounds - 01 Apr 2024 at 9:03pm |
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4874 |
Posted: 02 Apr 2024 at 11:31am |
I have some rocks just like Brian is showing. I know nothing about how to identify rocks. I just know this area is a geologic abnormally, in that things are very strange here. Things that don't normally show up in the same area can be found here. But the meeting of tetrionic plates (San Andrus Fault) and volcanic activity mixed things up a lot.
My property is in a limestone area, but several bits of sandstone pushed up into the limestone. I have been told more soil types in my county than most midwestern states.
Scott B
Joined: 14 Sep 2013 Location: Kansas City Points: 1055 |
Posted: 02 Apr 2024 at 2:09pm |
Sure looks like limestone which is prevalent throughout Missouri, Kansas, etc. Might be sandstone. Would also seem to align with your spring....water would flow more easily through sandstone/limestone vs. less porous granite, etc. Might explain why the water chose to "bubble up" where it did.
D17 Series 1
Allis B- 1939 Allis B- 1945 |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42270 |
Posted: 02 Apr 2024 at 2:53pm |
Seems one way to tell composition was a scratch test of base material , finding which material is harder - base or the stone used to scratch it .
Had to take a geology class when i did the Building Inspection classes - but the terms that were used and system was different that classes I had for Waste Water license . USDA was one and dang if I haven't slipped my mind on the other |
