Wheel Removal |
J. Larsen
Joined: 01 Dec 2023 Location: Lander, WY Points: 47 |
Topic: Wheel RemovalPosted: 29 Mar 2024 at 3:13pm |
I'm in the process of trying to remove the rear tires and rims on a WD45. I have no idea when the last time the eccentric bolts were loosened, maybe in 1955 when the tractor was new, and it has been painted at least once with a brush since then. I have used a 1" impact gun that removes some very tight lug nuts on semi trucks, and it doesn't even make any of the eccentric bolt even try to move. The tabs on these bolts are turned clockwise as far as the tabs will permit them to go, so I presume that the only way to loosen them is to go counter clockwise. I have even fashioned a heat shield to go between the eccentric bolt and the rim and tire so that I could use a rosebud on the torch to heat it up, but no joy.
Is there a secret that I don't know about to get these bolts to come free? All help is appreciated. Thanks, John
Joined: 11 Sep 2009 Location: illinois Points: 90999 |
Posted: 29 Mar 2024 at 3:28pm |
DANG... instead of a rose bud you might try a big cutting tip to keep the HEAT concentrated on ONE - TWO of the flats of the nut... get it RED.
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2235 |
Posted: 29 Mar 2024 at 3:58pm |
Take the wheel center rim and tire off the tractor, lay it on the floor, face up, then take the 8 bolts out of the center that hold the eccentrics onto that center. Take a block of wood lay it on the center and smack it very hard with a sledgehammer. May take several hard direct hits. The center should fall out of the rim and the eccentrics and hardware will fall off. At this point you can start the long process of freeing those eccentric bolts up in the eccentrics. That's another post. After you get them off you'll see why they wouldn't move for you on the tractor. Years of rust.
Leon B Mo Edited by Leon B MO - 29 Mar 2024 at 4:08pm |
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55326 |
Posted: 29 Mar 2024 at 4:43pm |
What Leon said^^^. And check out the thread on the knowledge section, particularly the video(s)...
Posted: 29 Mar 2024 at 4:58pm |
Has anyone tried ELectrolesis at this point ??
J. Larsen
Posted: 29 Mar 2024 at 6:10pm |
I have the 8 bolt out, and have tried a few love taps with a 5 lb hammer, but sound like I need to get serious!
Thanks, JL
plummerscarin
Posted: 29 Mar 2024 at 6:17pm |
Yes, I have. Of the 8 that I left soak for a couple days, only 3 needed heat afterwards |
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 29 Mar 2024 at 7:55pm |
When I am doing this task, I place the block of wood - a 2 X4, or a 2 X 6, or a 4 X 4, at the outer edge of the wheel, between any 2 eccentrics. And use at least a 10 lb. sledge, and a good strong hit. G |
ac hunter
Posted: 29 Mar 2024 at 8:35pm |
I have taken the snap ring off the back of the eccentric and removed it from the housing, sand blast everything and re-assemble with some lock tite.
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1128 |
Posted: 29 Mar 2024 at 9:00pm |
Wd rust release has worked on every one I have tried. That stuff is magic
SteveMaskey(MO)
Joined: 11 Sep 2009 Location: Wellsville, MO Points: 634 |
Posted: 29 Mar 2024 at 9:03pm |
The easiest way that I have found to free
up the eccentric is to take them off and heat cherry red and throw them in a
bucket of cold water. They will almost always come loose |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4285 |
Posted: 30 Mar 2024 at 7:15am |
I've 'cooked' a lot of them in the burn barrel. Hang them on a piece of wire over the side for easy removal, burn whatever is in the barrel and let cool. Every one I did this too came free quite easily.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7643 |
Posted: 30 Mar 2024 at 9:40am |
x2. I put mine in the wood stove for for night. By morning, they will turn pretty easy. Then remove the snap ring on the back and take the eccentric out. Sand blast and prime everything and reassemble. For removing the wheel center, I also do what Leon recommends. Never fails.
