an other starter question |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3952 |
Topic: an other starter questionPosted: 05 Mar 2024 at 6:35pm |
i see starters advertised latley, discrition says - will work on 6volt or 12 volt . so witch is it am i missing something ?
KJCHRIS
Posted: 05 Mar 2024 at 7:20pm |
A 6V starter will work with a 12V battery, so no need to update a properly working starter. But 12V won't work properly on 6V.
When you convert a 6V system to 12V system, (starter isn't polarity sensitive) (it's been going on for 40 years) most don't feel it necessary to replace starter. If you don't grind away on starter trying to start an engine that is in need of at least a tune-up, the starter will last indefinitely.
HudCo
Posted: 05 Mar 2024 at 7:37pm |
how can it be advertised that way its either 6 0r 12 sure it will work go on stiener and look up a starter for a 9n ford and read the discription other places have simular ads
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 05 Mar 2024 at 11:14pm |
What KJCHRIS says. I guess you can say that if it is actually a 6v starter. Hooking up 12v to it will only make it spin faster, but will kill it if run to long.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12027 |
Posted: 06 Mar 2024 at 6:27pm |
Sorry to disagree with you KJ CHRIS but you're wrong! Bad info there. You can run 12 volts through a 6V Starter motor, but its not going to last indefinitely! When running 12 volts through 6V field coils, it makes the Starter motor violent. In turn, eventually it's going to tear up a ring gear, crack a nose cone, bend or clean the teeth off the drive, or some kinda damage. Been doing this type of work for over 50 years. Trust me, indefinitely is not the word to use here...... Mike, someone has their head up their a$$ with that advertisement. You know as well as I. Its one way or the other..... LOL! Steve@B&B
Codger
Posted: 06 Mar 2024 at 8:04pm |
I'm not in that business at all but have seen and replaced a lot of parts including ring gears with teeth missing, stripped starter drive(s), (or those with sprag clutches torn out) and even commutator sections thrown apart from centrifugal force when doubling designed voltage input such as these incomplete conversions.
That's All Folks!
HudCo
Posted: 06 Mar 2024 at 8:19pm |
i guess part of it kind of pisses me off on how parts and part numbers are misrepresented just seen another ad for a crankshaft it did give a part number i did not check it out but it said fits wd45 d17 170 175 and the guy selling the parts aint going to know, we are restoringing a 9n for a guy and he wants it all 12v well i dont want to spend my money on a 6v starter and if it was staying 6v it sure would not do any good to have it turn out to be a 12v starter how many of you guys ever used 8volts battery in your 6v system, i have not installed one of those for some one in at least 10 years
Les Kerf
Posted: 06 Mar 2024 at 8:40pm |
My late Father-in-law ran an 8 volt battery in his WD for 30+ years, seemed to work fine until the engine locked up one winter (totally unrelated to the 8 volt battery). I have the tractor now, it is on my long list of projects.
Codger
Posted: 06 Mar 2024 at 8:56pm |
I have seen several older tractors around here with eight volt batteries installed, but have never installed one myself.
That's All Folks!
Steve in NJ
Posted: 07 Mar 2024 at 9:06am |
An 8 volt Battery is a band-aid. If the customer wants the system changed over to 12V, do it right and do it 12 changing ALL components. If he wants to keep it 6V have the components totally rebuilt the correct way, and the system should work fine. BTW, 8 volt Batteries are a PIA to charge. Like I said, they're just a band-aid for an existing problem. Sluggish Starter, undercharging Gennie, old or under gauged wiring, etc. Steve@B&B
Edited by Steve in NJ - 07 Mar 2024 at 9:10am |
HoughMade
Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 711 |
Posted: 07 Mar 2024 at 9:23am |
The way I look at it, these engines were made to start on a hand crank. You shouldn't need much cranking and it shouldn't need to crank faster than a good 6 volt starter can manage. If the starter spins virtually at all, if it doesn't start in less than 10 or 12 revolutions, something else is going on- carb, mag (or distributor), plugs, etc.
Edited by HoughMade - 07 Mar 2024 at 9:26am |
1951 B
Les Kerf
Posted: 07 Mar 2024 at 1:25pm |
Agreed. If the engine is plumb worn-out, as was the situation with my Father-in-law's WD, then a bit more cranking speed can be helpful. When you can hand crank an engine and hear the compression leaking past the rings, you know you have problems. He kept that old WD going until he could no longer drive it, so I reckon it was good enough for him, and now it is SEP (Somebody Else's Problem). I intend to rebuild it back to stock including 6 volt generator. Just because. |
Steve in NJ
Posted: 07 Mar 2024 at 5:57pm |
Sounds like a plan Les!
