7040 Info |
Siemers
Bronze Level Joined: 04 Mar 2024 Location: SE MN Points: 6 |
Posted: 04 Mar 2024 at 9:25pm |
Hello everyone, I am new to the forum. Hoping for some help.
I am trying my hand at farming for the first time this year. My dad & I bought a 7040 Allis this winter. We don't know anything about orange tractors but the one we got is very clean with only 2300 hours on it. Tranny has the power director in it. Tractor Data says 136HP @ the PTO. Anyway, I am looking to buy a field cultivator for it but I don't know how big a 7040 can handle??? I can find 24 foot wide cultivators all day for sale but my gut tells me that size is too big? I know it depends on soil conditions but can anyone shed light on this? I'm in SE MN and the farm is my grandpas with good black dirt. Thank you!
jiminnd
Orange Level Joined: 16 Sep 2009 Location: Rutland ND Points: 2238 |
24 foot should be ok, you will need duals and some weight. depending on how many acres smaller may be better. I had a 7030 and used 24 foot for the tractor its whole life.
Siemers
Thanks for the info jiminnd
How fast & deep could you run it? I would like to run it @ 4" deep. I don't have duals on it, hopefully within the next year. I do have Lots of weight up front. |
jiminnd
I think about 3 to 4 inches at 5mph.
Orange Level Access Joined: 12 Sep 2009 Points: 20580 |
Tractor must have duals and good rubber on all four rear tires. A field cult ain't a chisel plow. 1/2" too deep and it will pull much harder. Four inch sweeps will pull easier than 6 inch sweeps. I have customers who pull 28 feet behind a 7040 and think that's just right. I have others who think 24 ft is just right.
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8407 |
Get yourself manuals for that tractor.
NEVER green
Orange Level Access Joined: 28 Feb 2013 Location: MN. Points: 7528 |
Remove the weight up front.
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11619 |
Definitely want duals. I don’t know your soil and lay of the land. I pull 24 feet with a 7045 which is an updated version of your 7040 so to speak. I also pull an Unverferth rolling harrow behind the cultivator but I needed wheel weights to be satisfied pulling all of that.
If it was mine, I'd want fluid in the rear tires. You may need fluid (1600 lbs) and you may not. close call on that.
Tbone95
I have fluid and inner weights! Not so much for the field cultivator but it plows a whole lot better now. And I keep the front weights on, when it starts pulling harder the nose stays down. With all that it will power hop at the worst case scenario. |
Siemers
Thank you everyone for your input. I was afraid I would need duals.
Unfortunately I am on a fixed budget so It might be a little bit before the duals get put on. The other problem I have is since I bought this tractor with my dad, we kinda have to agree on things to do to the tractor. He is against putting duals on the tractor. He said he talked to an old Allis Chalmers mechanic that claimed duals are hard on the rear ends of those tractors? Anyone heard of this? I have seen plenty of 7040's with duals on them.... |
bigal121892
Orange Level Joined: 05 Jan 2010 Location: Nebraska Points: 804 |
If that were true, there would be a lot more rear end failures, because just about everybody uses duals.
How about THOUSANDS of them with duals !!!! The old mech needs to just go away with bad information like that.
Edited by DrAllis - 05 Mar 2024 at 5:48pm |
Siemers
Thats kinda of what I was thinking, lots of old tractors with duals.
I will try and post a picture of my 7040 later.
Thanks everyone for the help. |
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3498 |
This is mine pulling a 30ft.
Loaded tires with duals. Fair amount of slippage without duals |
8070nc
Orange Level Access Joined: 21 Mar 2019 Location: North Carolina Points: 506 |
We ran a 7040
8000 hours with duals with liquid in all 4 tires |
1984 80780
Acguywill
Bronze Level Joined: 15 Jan 2024 Location: Vauxhall ab Can Points: 89 |
I would look for a cultivator with bolt on extensions. That way you could remove them if you can't pull the full width with your current tractor setup. If in the future you get a set of duals and add some weight you just bolt the extensions back on. You must have easy pulling soils to be able to pull 24 ft with 140hp. We had an 8070 fwa with 20.8 radial duals, full weights front and rear, and fluid in the fronts and inner rear tires pulling 29 ft with harrow and packers and that was all it could do. At 4 inches deep I think it was 4th gear with the powershift transmission and stay away from anything that looked wet.
Tbone95
I see you have the front weight on too. I was never happy with my 7045 pulling until I got the total weight up around 15,000 pounds. |
What the OP fails to understand is using duals makes the field cultivator do a better job. It doesn't have tracks 4 inches deep to make go away. Tractor performs better as does the field cultivator. This assumes FOUR GOOD tires, not bald.
Leon B MO
Orange Level Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2114 |
First, duals are a must especially in loose soil. We pull a 22' Great Plains field cultivator with 3 bar harrow and rolling baskets. It makes a nice seed bed. I can pull it with the 7020 but only 4.5 mph. The 8050 will handle it at 6 mph plus and the speed makes a more level seed bed. Don't be afraid of a smaller tool pulled at a higher speed. It does give you options with your pd trans. Also the older ones will not handle vegetation nearly as well as the newer models. Wider sweeps and less shanks will get through more trash. Ours has 9" sweeps. Wish you the best.
Leon B Mo |
Siemers
Thanks again for all the input everyone. I tried to upload a picture of my tractor but I could not figure it out...
