Perkins 248 engine "WANTED" |
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2259 |
Topic: Perkins 248 engine "WANTED"Posted: 28 Feb 2024 at 9:50am |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5083 |
Posted: 29 Feb 2024 at 6:49am |
IIRC, the 248 comes in different blocks and they are not interchangeable.
Macon Rounds
Posted: 29 Feb 2024 at 7:43am |
Thanks for the info .
I need one for an Allis Chalmers 175 tractor. Is there a designation on the block. Here is ID on mine.
Macon Rounds
Posted: 29 Feb 2024 at 7:59am |
Let's see ?????
Should I reply to this guy ?????? Joined January of 2024. No points. Location UK. Just another scam Grrrrr !
Codger
Posted: 29 Feb 2024 at 8:15am |
What WF is referring to is a "Stress Block", and conventional block engines. They are not interchangeable at all. The "Stress Block" does not have a bolt on rear flywheel housing and the these are used a lot where the tractor engine is part of the structure of the tractor meaning no frame rails. On the left side of the engine there should be an aluminum tag riveted to the block. Many 4.248 engines were stamped "LG" build. If the tag is missing, there should be stampings into the block above the injection pump just below the cylinder head deck, or same place at the rear. There is also a different crankshaft layout. One has a single large bolt, the other a three bolt affair retaining the front pulley(s). There are also differences internally but need to know what you have before going much further. A 4.236 will be a slip fit also if the same basic block.
That's All Folks!
Macon Rounds
Posted: 29 Feb 2024 at 9:16am |
Thanks for the info.
I'll be checking for those specific details. Thanks !!!!!! |
WF owner
Posted: 29 Feb 2024 at 8:03pm |
I'm trying to remember what DrAllis said, but I think he said that the AC 175 used a different block than the Massey Ferguson 165/175/180.
Codger
Posted: 01 Mar 2024 at 7:11am |
I have a friend with a Massey 175 and it uses a stress block 4.236 engine. I've never seen a 175 diesel Allis myself so cannot vouch, nor deny culpability in that application. Keep in mind those engines were produced in gasoline variants also; though I've not seen a 4.248 with anything but diesel myself.
That's All Folks!
