7060 Hydraulic oil leak |
AC 426 power
Orange Level Access Joined: 01 May 2012 Location: Ohio Points: 514 |
Posted: 20 Jan 2024 at 2:07pm |
Got a hydraulic oil leak out of the filter housing where the filter sensor goes in and according to agco parts there is a oring behind it, my question is if I popped this out is 17 gallons of oil going to come out with it? Was wondering if I could replace it without having to drain the oil, recently had a unscheduled oil changed due to a broken valve in the filter housing during a routine filter change and of course I now just noticed this leak after I’ve already filled the system again.
Orange Level Access Joined: 12 Sep 2009 Points: 20184 |
You'll lose about 2 gallons tops.
AC 426 power
Michael V (NM)
Orange Level Access Joined: 12 Sep 2009 Location: NM Points: 2385 |
Ya might try the vacume cleaner trick, hook up a shop vac to the filler. My brother says this works..
Edited by Michael V (NM) - 21 Jan 2024 at 6:58pm |
AC 426 power
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3373 |
Yep, that works.
NEVER green
Orange Level Access Joined: 28 Feb 2013 Location: MN. Points: 7211 |
??????????????? This works? Where you guys yrs ago!
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 8091 |
Sometimes pictures arent your friend - looks pretty rough- clean everthing up - bet it work out
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8159 |
Vaccum might work even "better" if that side run up on a big block? Does that little "sender" ever fail? My PD 8070 has that filter light on and off randomly even after new filter (AGCO) changes. Often wondered if removing and cleaning it would help. It is a grounding thing so what if it had fine metal buildup/deposits over time? Have checked wiring to the best of my ability to see that insulation isn't worn through causing ground.
plummerscarin
Never had an issue sitting flat on the floor. Stick the vac hose over the fill tubes. Just make sure your over the correct one. Did that replacing drain plug washers. Learned that trick when at CEI and needed a fast way to fix oil leaks without having to locate a barrel to drain 40 gallon reservoir.
