1940 Allis Chalmers b
Hardwater000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardwater000 Quote  Post ReplyReply Direct Link To This Post Topic: 1940 Allis Chalmers b
    Posted: 18 Jan 2024 at 6:47pm
Restoring a, b tractor have a question about the steering column original has rust holes, was wondering about the square piece welded to the column toward the bottom above the steering box. What is it's purpose? Plan on making my own column and was curious about that piece.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2024 at 7:27pm
On the early 'B' tractors, that was where you stored the hand crank. I have a '39, crank start only and all original.  I'll see if I can get a picture of it showing the crank in place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2024 at 7:50pm
i dont know if you have measured the tube or not... but it is the same as a steel Conduit.. you can buy a section at the Hard Ware store.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2024 at 5:48pm
Here is a picture of the crank in it's storage place on my '39 'B'.
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2024 at 3:08am
Hy
Where is the crank storage place on B or C which have a battery box ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardwater000 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2024 at 6:17am
Ok I was starting to worry that maybe I was missing something that it may bolted to, but it doesn't have any holes in it to bolt to anything. Yes I was going to build one out of thicker material I think other than coming up with a type of bushing it Shud work I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2024 at 8:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2024 at 10:23am
The B's that were equipped with a Battery, the crank was on the shelf in the barn...  Wink
Steve@B&B
