7000 hydraulic pump kit |
dp7000
Bronze Level Joined: 26 Sep 2021 Location: Winchester Kent Points: 138 |
Posted: 17 Jan 2024 at 9:45pm |
Hello Big Orange experts. Where’s the best place to get a kit for a black belly 7000 hydraulic pump? I searched archives and didn’t find any recommendations. Thanks much. dp
Orange Level Access Joined: 12 Sep 2009 Points: 20184 |
I've bought two kits from A & I and was happy with the parts.
dp7000
Thanks Doc, exactly what I needed to know. I value your experience and opinions.
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3275 |
We use the A&I kit but if we need individual parts the AGCO old White/Oliver PN#s are still available. 20-7300762 20-7300763 20-7300764 are the outer ring and eyeglass seal both blue and soft black. 24d001 is AI the kit with plates and 70255947 is the AGCO seal kit w/o the wear plates.
Hurst
Orange Level Joined: 11 Sep 2009 Location: Midway, Ky Points: 1211 |
Is the 24d001 the one for the 2 section pumps the 7000's use? Just verifying because the online retails I have found don't list the 7000 in the application list, but I thought the pump was more or less the same as the 200 pump.
Hurst
1979 Allis Chalmers 7000
5800 Hours |
Kit for 180/185 will work extra parts leftover.
dp7000
Interesting, I think the front seal is out on mine. Was using tractor to unroll hay, backed up to a roll and lift arms wouldn’t raise. Heard a pop but don’t know if it’s related. Was very cold. Steering worked as well as power shift. As I returned to the barn to change tractors lift very slowly came up. I looked in the hydraulic filler tube and saw oil moving with air bubbles. Do you think front seal is all that’s needed?
My experience with the front seal is the pump loses it's prime. If it has blown out I'd expect engine oil level to maybe raise ??
dp7000
Engine oil unchanged. I think it’s sucking air. I read on another post there’s an elbow underneath? I haven’t looked into that yet. It’s been too cold. I don’t have a heated shop.
Hurst
If sucking air, check the elbow and also the doughnut gaskets on the suction line at the pan.
Hurst
5800 Hours |
