D17 fuel gauge leaks
mnjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnjoe Quote  Post ReplyReply Direct Link To This Post Topic: D17 fuel gauge leaks
    Posted: 14 Dec 2023 at 8:13pm
I just bought a series 1 D17 gas. Moving it around and trying out the 500 loader I noticed it was wet under the fuel gauge. The gauge is mounted with allen head screws. What is the best way to fix this ?  Thanks Joe
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 8:20pm
I used the large fuel bowl gasket with the white thread sealer on it  on my D 14 over 10 years ago n its still dry
nonetheless ,still dead.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 9:02pm
I used an 'O' ring under the last leaking gauge and hasn't leaked since. But that has been only a year or so ago. So it is in experiment mode for now, only time will tell how it will perform.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 10:24pm
I just replaced the gasket under the gauge on my series 1 diesel a few months ago after I painted the tractor. It hasn’t leaked. Make sure the tank lip is clean and free of paint chips. The gasket has to have a smooth clean surface in order to properly seal.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2023 at 5:45am
AGCO Part # 70228119 they have it
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2023 at 7:31am
I think DJ's also has the gasket. I replaced the gauge and gasket on mine a couple years ago.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2023 at 8:14am
I have had four D series tractors now, replaced, or need to replace that gasket on every one of them! They leak almost as bad as sediment bowls.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2023 at 9:11am
It has to be a neoprene gasket.  As mentioned above, easily available through DJS, Steiners and AGCO.  I have replaced all of mine already.  After almost 60 years, they usually need it.
This page was generated in 0.032 seconds.
