D19 diesel radiator |
Tim-tn
Joined: 15 Sep 2009 Location: West Point ,TN Points: 206 |
Topic: D19 diesel radiatorPosted: 29 Nov 2023 at 6:54pm |
In need of a D19 diesel radiator, does not have to be good, I have parts of one, I need the bottom tank, side frames and the fan shroud.Let me know what you have. Thanks...?
Posted: 29 Nov 2023 at 7:07pm |
Gas or diesel should be the same.
Tim-tn
Posted: 29 Nov 2023 at 7:26pm |
Thanks Doc, I thought that to be the case, now not arguing but wasnt the diesel core thicker than the gas core? The reason I ask is I had a diesel radiator that the top tank came loose from the core, carried to rad. shop, for repair, they told me the core was bad, I seriously doubted that it was but I needed the tractor so I got a new core, I kept the old core, now I am repowering a D19 and need the radiator, carried the gas radiator to a different repair shop to have the thicker diesel core installed, they call and tell me that the bottom tank, and components won't work. Thoughts...... Thanks
Posted: 29 Nov 2023 at 8:59pm |
There was an "early" radiator that had a very long neck and a shorter (D-17) height core. They were soon subbed up to the later taller radiator. The diesels should have had a thicker core but not sure they really did in the end. For sure they would interchange to fit in the same spot. Maybe A-C had two suppliers thru the 3 years they were built ?? I wouldn't be able to prove that (or not). AGCO parts does show diesel with a diff p/n, but like I say, near the end, why not the same for both?? cost couldn't have been that much diff compared to two different ones.
Edited by DrAllis - 29 Nov 2023 at 9:02pm |
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2051 |
Posted: 30 Nov 2023 at 6:56am |
I have a gas radiator. Leaks but the tin is nice.
http://lonsallischalmers.com
Tim-tn
Posted: 30 Nov 2023 at 1:38pm |
Lon sent you a PM. Thanks?
