D17 rear tires needed.
twinson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Topic: D17 rear tires needed.
    Posted: 19 Nov 2023 at 5:34pm
What are good tires for a Allis D17 Series I (brand)?
Currently have 18.4/15-28 but need to replace tubes and might as well do all at once.
Also, liquid ballast or not?  Plowing days are over, it will just be a utility tractor for now.
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 5:40pm
put 16.9x28 tires on it and do not put fluid in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 5:41pm
BKT is a good tire at a good price
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 6:00pm
I'd agree. I've had a set of BKT's 14.9 x 28's on my WD45 (that I plow with when the chance arises) for 10 years now.
Edited by DrAllis - 19 Nov 2023 at 6:00pm
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 6:27pm
I just put a set of BKT 14-9x28’s on my 45. One reason is I’ve had good service from the BKT 12.4X24’s on my 2 CA’s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2023 at 8:56am
Which model BKT tire? I know they offer many.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2023 at 9:06am
16.9 x 28 bias ply "R-1" 6-ply rear tractor tire. Didn't know they had more than that other than a radial.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2023 at 9:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2023 at 3:48pm
14.9 is too small for a D17.  Go with 16.9.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2023 at 5:10pm
The only time I thought 14.9's on a D-17 was appropriate was a customers series 1 with a manure loader and a low shed door. He even had the muffler laying horizontally to get in that door it was that low.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2023 at 9:03am
had a D-17 with 14.9x28's that I thought looked just right. Cause I was getting ready to sell it!
I noticed a 180 at the tire shop the other day that was in for new shoes. 18.4x28's came off and were there. Firestone's, pretty worn and some cracking but still usable. I could inquire with the owner as to their availability? Tires that size are pretty hard to come up with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2023 at 9:15am
I have a pair of Firestone 18.4X28 tires with new tubes.
 I also have a pair of Goodyear tubeless radials 16.9X28.
 Located in Maryland, very near Gettysburg Pa.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2023 at 9:16am
So, I went back to the tire shop yesterday. Those 18.4x28's are probably better than I thought, however, they will not be for sale as they are going on one of the current owners other tractors. When they get the rim situation figured out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2023 at 10:15am
Do they need a pair of rims for 18.4 x 28's ?? I've got a pair.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2023 at 10:23am
how do 18 .4 28 look on a d17?
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2023 at 10:37am
I don't know off hand what size rims you have but I have a set of
take off's trelleborg tires that are 540/65/38,they will fit
a 16x38 rim,but they may be to big for you,they are on marketplace also..
Oldwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2023 at 1:01pm
"how do 18 .4 28 look on a d17?"
Our IV had 18.4's on it when we first bought it used 40 years ago.  I put on 16.9's a few years ago when it finally got new tires.  I think the 16.9's are perfect for this size tractor.  They just look right. The 18.4's were too wide and just looked like overkill.  If you plowed they were too wide for the furrow.  Forget something like cultivating.  Each to their own, but for an all-around utility tractor, I wouldn't put 18.4's on it again.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2023 at 2:41pm
Oldwrench I totally agree with you!
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2023 at 6:44pm
i know this is getting off the orignal post mine does have 16.9 x 28 and they are very close to the top of the fenders ,  i think they look good .  tires that are taller than the fenders i think looks bad.     but i want to put 9.50 x15 or 11.00 x 15 on front  as long as the top of the hood sits level
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2023 at 5:30am
Well, I don't know, you could give them a call. Hewitt tire, 641-259-2097, ask fort Steve.
I mentioned the 18.4's because I think some series's 4's had them and they are a hard size to find. I have lots of 16.9x28's around here, four tractors, one set of duals, may be a spare or two out there? All my 18.4's are 34's or 38's. Just brought home my first, (and probably only) set of 20.8x38"s.
