B pick up plow
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: B pick up plow
    Posted: 18 Nov 2023 at 10:59am
Anybody know about these plows
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 4:50pm
I find a number of old forum topics on the subject using the search button above.  Seems like some of those do quite a good job on the topic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 4:54pm
Ok my question is I put a good rebuilt plow share on now it will not go in the ground
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 5:00pm
look at the angle with respect to the ground... the point has to be LOWER than the heal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 5:26pm
Change angel with the lever next to gas tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 6:07pm
yes. lowering the pin hitch in the front, should drop the point on the plow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 11:09am
The operators manual should tell you how to adjust plow.
I’m curious what was done to a plow share to rebuild it.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2023 at 8:00am
Mike, I 'rebuilt' one with many many feet of .035 wire from the welder. Probably won't do that again. Took forever and a trip to a buddies Bridgeport to get a cutting edge back. It does plow better now though.
This page was generated in 0.328 seconds.
