I'm harvesting...WooHoo! |
Page 12> |
![]() ![]() ![]() ![]() ![]() Posted: 08 Nov 2023 at 10:07pm |
finally got the second oil filter off, I grabbed the new ones that I had carried up with me a few days ago, went to wipe sum oil on the gasket and a whole bunch of shelled corn fell out of one of the new ones! I spose a mouse carried them up and put them inside the filter overnight! It went to a lot of work last night! got them all cleaned out and got both of them on, I love combining corn! filled with oil, then got the new batteries installed, the combine started right up, checked for any leaks and found none! WooHoo! lifted the head up and tried to latch it to the combine, but that is a no go for now. It's heavy nuff, it'll stay down, I just won't drop/run the snoots on the ground. went out and combined a wagon load and filled the combine again, no issues, just did end rows today/tonight. appears all the lights still work. Old Glory is wav'in in the breeze above the combine. I'm happy so far, I love combining corn, it's the reward of the work all year! a friend came out and helped me some on this machine, he has one like it in his shed...said they do great on crops and give great samples. not bad for a 42 year old machine! I'll resume tomarrow after I hook up the Dodge to the wagon. Thanks to you all too for the helpful hints while I was getting this machine ready!
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34358 |
Good to hear, now get out there and git'r done! WooHoo! WooHoo! WooHoo! WooHoo! Nothing like when everything is working good. Geez Dale, when you going to start postin pictures for all of us to see your thrills... ?
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8658 |
Get a buddy to help get that head latched on. That could cause an ugly problem.
200Tom1 ![]() Orange Level ![]() ![]() Joined: 03 Jun 2019 Location: Iowa Points: 1232 |
Dale, Get that dam head hooked up. I was fixing a tire on a 1460 Binder several years ago. I got the tire fixed. Set the machine down crawled out with the jack in my hand and I had gotten to my knees when that 6 row head hit the ground. A few seconds earlier and the old gal would have been a widow.
NEVER crawl under any cornhead or header on a combine without the safety ram or a big olestrong something under it! (I use the safety ram and an unused combine wheel under it)
I'll try to get it latched today before doing the hills.
Dennis J OPKs ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Overland Park, Points: 541 |
Not trying to scare anyone but there are encounters out there about this subject. Matt Griggs who is a you-tuber from TN is an example and his video may still be available. He was on the road in a pretty new CIH combine. Head either wasn't properly secured or became unfastened if that's possible. He hit a dip, head came loose and combine attempted to leap-frog over the head. Matt was ejected out the front of the cab into the carnage. He probably wouldn't be alive except the hydrostat line was severed & the combine stopped. Combine was rebuilt & in use today. He is also a believer in seatbelts when on the road. It's a miracle he survived.
captaindana ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2573 |
Way to go Dale! I too really miss pickin’ corn n combining oats!
Blue Skies and Tail Winds
Dana |
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6496 |
Glad you got it going. Now you can play with it instead of that darn machine.
Wayne180d ![]() Orange Level ![]() Joined: 08 Dec 2015 Location: Gilman, Il Points: 5942 |
What machine do you have?
Wayne...it's an IH 1440 rotary.I hauled about a semi load into town today behind the Dodge in a gravity flow wagon. it's faster with the pickup cuz the wagon will trail straight and smooth up to 45 MPH empty. on;y ggo about 15 when full. was told today that the elevators will all be closed over the weekend, so a buddy of mine will bring 2 of his semi's to me to fill over the weekend. that will help BIG TIME! still gonna fill the gravity flow too.
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 8138 |
How many acres do have Dale?
WAY TO GO SHAMERS!!! Makes my heart feel good to know that you're happy and won't have time to play with that other infernal machine! Although they're talking a little of that white stuff tonight/morning. Good way to start Veteran's Day. Have FUN Buddy and stay safe!
well I was harvesting, seems a gathering chain has come off and is wedged just under the deck plate...TIGHT! PfffffT! I have never replaced or had a gathering chain give me problems before, of course it couldn't be one of the middle ones, where the tin work can move out of the way...had to be the very end one on one side. takes the whole head down! PfffffT! will work on it tonight, gathering up work lights, I have no idea what size wrenches will be needed yet. can't see up in there to see, can feel it, if i'm feeling the right thing! it's COLD out there! anyone know what size wrench i'll need? not much room to turn one either way.
Wait till daylight, the corn will still be there. If you are itching for something to do, go chop corn stalks, or start fall plowing.
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 966 |
Get the latches set and use the cylinder safety lock before you tackle the gathering chain.
I'll guess the spring tensioners got rusted while setting and got pushed back and stayed there. Then the chain jumped off.
almost done....cept another gathering chain jammed and locked the head up! PfffffT! looking at it tonight, appears them gathering chains are just wore out! this one the chain pulled apart after the chain pin came out! next link shows alot of stretch wear...I only gots about 4-5 acres left, i'll replace this one with new and worry about the others next fall since the corn head hasta sit outside all year. don't want new chains out in the weather all year. oh...and I gots a grain leak somewhere on the combine, can hear the grain dropping, but can't see it. I leave a little pile when I stop to unload. it isn't much, be good food for the wildlife! lol
Since your so close to done, just run without that outter row chain on... mmm I suppose this chain is somewhere in the middle? Just put a new link in and finish, then buy all new chains next year. Just a thought. Shameless, you need to start taking pictures of your harvest / combine and post them on here.... You can do that, if not get yur ol' la.., ah er, your luvin wife to post them for you. ![]() |
I 2nd what Jerry said. No pictures? = It didn’t happen!
Edited by Lars(wi) - 12 Nov 2023 at 11:26pm |
gots the 2nd new gathering chain on, there's no connecting links on the new chains, they are already in a loop. gotta almost take the whole adjustment slide off the head to put the new one on. anyway, got the new one on and am going again. I gots a grain leak somewhere on the combine, can't see it, but can hear the kernals dropping...think they are dropping back inside the machine, then filling up inside, then dropping outside on the ground. I just start the machine slow and the kernals will come back up and dump into the grain bin. I spose I gots a hole in the grain bin somewhere I can't see! I have about 2 wagone loads left and i'll be done for this year. took the semi loads to Cargill, they told the semi drivers that my corn was the cleanest they have had all year come in. that old combine is still working good, sucks that it's gots so many leaks all over it. I may hafta replant corn in that field again just to keep the costs of chemicals down to kill any volenteer corn in it! lol
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3932 |
You might have it half seeded already!!
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4756 |
![]() ![]() ![]() ![]() ![]() ![]() Always a good feeling to be done harvesting.
I'M DONE!!!!! finished up this afternoon. took the last load in behind the Dodge, but stopped at a gas station and grabbed a 12-pack...shared it with the elevator manager and employees after dumping out the wagon. The manager told me he liked the way I think! lol now i'll gits the combine cleaned out, open the trap doors, take down Old Glory, and hopefully park it where it won't be in the way for a year! It feels good to be done, but will miss it out there at night combining, I love combining corn at night, cept my light quit on the unload auger, had to hold a flashlight out there to see when to move and not run any grain out over the side. I sold all the corn I have at the elevator for $4.90 a bu. what are the prices where you are at? the Cargill plant pays more than that, but don't know how much yet. the prices change about every 10 mins there. I also saw the longest semi grain trailer i've ever seen while at the elevator, long sucker...triple axle with a another lift tag on the back, I asked how long that thing was and the driver told me 50 ft....BS....I have a 53 ft at home and this one is way longer than mine! he just smiled and walked off. had nice weather all thru harvest, only 2 breakdowns and both were the gathering chains on the new to me corn head...no biggy! combine ran great, always started, thought that was pretty good after sitting outside 8 years in the weather. everything electrical worked, no mouse damage that I could see, just had the trouble with the filters, but can't really count that as a breakdown. well I did hafta gits a new tire before starting out. I feel fortunute on the holding up of the combine since I watched the big servive/repair trucks from the green stores go by every day and sometimes more than once...them are all newer and some real new and are broke.
Way to go Dale!! How many acres do you have?
Edited by Lars(wi) - 15 Nov 2023 at 9:54pm |
all together 72
O, heck your just getting back in the groove. Your off-season assignment is to secure rent/lease on an additional 72 acres of tillable land, and every off-season from here on out. We’ll get you back into BTO swing of things in no time flat. |
klinemar ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Michigan Points: 8060 |
Always a good feeling to be done with harvest!
Thanks Lars....but no thanks. this is nuff for me, I don't move around as fast as I used to, but it sure was fun again this year to be out there doing the farming thing even if it was on a very small scale. I haven't got my tally sheet yet as to how many bu per acre I secured. would have been more i'm sure had I found all the leaks in the combine! lol anyways I wish I was still combining corn, I love that...especially at night. oh...and i've been looking at a 12 row 30 inch planter, you spose that would do the job a little faster? lol...it would gits the neighbors jaws flapping anyways! anyone know about the WHITE brand planters?
desertjoe ![]() Orange Level Access ![]() ![]() Joined: 23 Sep 2013 Location: New mexico Points: 13729 |
Well, GOOD BUDDY,,,it gives me GREAT Pleasure to see you enjoying yourself getting back to farming as it is obvious you really loved doing that,,,!!! Just Be Careful and don't overdo it,,!!
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4109 |
I wouldn't be afraid of a White planter one bit. Only thing, there are A LOT of wear parts on a 12 row!!!
Page 12> |
