WTB Ford 460 ci motor |
Leon B MO ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2077 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Nov 2023 at 8:40pm |
Well we vented the 429 in the 79 tandem grain truck, totally my own fault. I hate to just junk the truck. Looking for a running 460 big block to drop in for next fall. East-central MO. PM me here if you have something.
Thanks all Leon B MO
Macon Rounds ![]() Orange Level ![]() ![]() Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2096 |
429 ?????
In a grain truck ? Send me a few photos... |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 19714 |
429 was used in medium-duty trucks and isn't the same as a 429 in a car or pickup. I don't know how much different the 460 is, because it was never used in a medium duty truck to my knowledge.
I'd be interested in either one. It did ok with 625 bu of corn but it just goes from farm to farm.
Leon B |
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2162 |
I've got a good running 7.3 diesel for sale in central Iowa.
Would that bolt right in place of the 429 as far as the bell housing of the 13 speed Eaton transmission? Does that come with a turbo also?
Leon B |
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11602 |
It might be easier to find either a 389XD or 391 truck engine. I think they were in the same family as the truck 429. The passenger car version was different, but for the life of me I can't remember what that difference was. Block casting possibly. (?) You have to watch on the Medium and HD Ford Trucks, the engine blocks had differences between the years. Typical Ford. Kept changing stuff year to year....... LOL! Steve@B&B
thendrix ![]() Orange Level ![]() ![]() Joined: 04 Feb 2013 Location: Fairmount GA Points: 4764 |
I believe you're right doc. I want to say the 460 was used in 3/4 and 1 ton trucks and motorhomes. If I remember right the bore was the same with a longer stroke |
Ed (Ont) ![]() Orange Level ![]() ![]() Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1231 |
A lot of 460's in motor homes. My friend has one in a 97 coach. Does a good job and not too bad on fuel. Works hard in hilly country and of course sucks up a lot more fuel then. This one is TBI.
361-389-391 same family. 370-429 TRUCK engines same family. Not saying the 460 bell housing wouldn't bolt up, I just know it's not an Industrial H.D. version probably without a steel crankshaft, sodium exhaust valves and forged pistons.
Codger ![]() Orange Level ![]() ![]() Joined: 23 Dec 2020 Location: Illinois Points: 1874 |
I can't answer for the truck versions of the Ford engines as never really ran anything other than a 330 in an old F-600. It did alright for what it was. If not against converting to diesel, a good IH DT-466 would be a good fit and pretty much match what you had for power. May even best it. Not priced anywhere near a 5.9ltr Cummins engine either from my experience. it wouldn't be a slip fit, but not difficult either. Depends upon your fabrication skills and tolerance for trial and testing while proving/correcting errors. SAE flywheel housings and flywheels are readily available in SAE #2, and SAE#3 also to match your transmission.
This replacement motor doesn't need to a hot rod. Dad did have a 460 in an 80 1 ton pickup, got 6 mpg, that's why I asked if one was available. I have 925 acres in a circle of about 10 miles to the central local where my bins are at. I'm a small fish if a big pond. I have the 79 ford 429 and a 76 chevy with a 427, both 13 speed Eatons ,twin screw. For what I ask of them they are perfect. Actually the chevy will hold about 50 bushels more but that truck has more guts than any 427 I've been around and will definitely out do the 429 with less bu. Not really concerned about fuel consumption, both trucks only go through about 4 tanks of fuel in the fall. More concerned about power to get out on the road and out of the way of everyone else and also to get from a soggy, hilly dirt farm road to the bins. I hire a semi to take the grain to ADM. Thanks again for all the input.
Leon B MO
I drive this during harvest for my cousin. About 680 to 720 bushel of corn or beans each trip and the truck does very well in this task and been doing the same thing for several years for him:
![]() Edited by Codger - 03 Nov 2023 at 8:52pm |
The 7.3 diesel that I have is a non turbo, no emission engine. It came out of a 1990 Ford E3 one ton shuttle van from an airport parking lot. It had a transmission problem and was taken out of service. Approximately 70,000 miles on this engine. We had the engine out and running on the floor of the shop. A battery and fuel supply is all it took. Runs good. I don't know about other transmission interchange possibilities.
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 4801 |
370/429/460 are all the same family, same bellhousing. 370 was only hd truck engine, 429/460 could be truck or passenger car engine. I'd think any 429/460 would bolt in, just not 100% sure the flywheel bolt pattern is the same on the truck engine vs car. The FT series, HD version of the FE series is completely different including it's round bellhousing. I'd think there would be enough 460's out and about to find one. Thinking about it more makes me think back of crank is different for bigger pilot bearings. I do know the FT/FE differences are significant on the front and rear of cranks. 429/460 not sure about though. I still have a 429 that came out of a buddy's ranchero he put a 460 crate motor in. Was running fine when removed, but it's been sitting in my shed for 15 years. I've kept as spare since we have a drag car we run 385 series 460 engine in. Haven't raced it in a decade lol!
