Christmas came early |
Macon Rounds ![]() Orange Level ![]() ![]() Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2229 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Oct 2023 at 1:47pm |
Christmas came early .
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
I seem that before .
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5243 |
Looks to be in great shape! Congratulations
SilverShoes ![]() Bronze Level ![]() Joined: 20 Feb 2014 Location: Seneca, Kansas Points: 170 |
Very lucky!
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5035 |
I was a (pretty) good boy, Santa!
Nice find!!!
My SMALL crop is harvested for this year....
Spoke to a neighbor and we're gonna play dueling corn pickers on his crop when weather allows for harvesting.... Then it will go into dry storage for the winter. |
Now that IS a Merry Christmas Benny!! Good find!!
It should be washed off good by now .
D15 or D17?
15
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5602 |
What row width are they made for? That is a great looking picker. You will have fun with that.
AllisFreak MN ![]() Orange Level Access ![]() ![]() Joined: 07 Dec 2009 Location: Minnesota Points: 1588 |
Me jealous.
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4101 |
Nice!
Would be cool to watch a video from a go pro mounted to the fender while you run the picker.
I don't believe this tractor picked corn with this picker.
Radiator is spotless and several other adjustments indicate initial installation.... Pulled it up to garage for service.... Fun fun !!!! ![]() ![]() ![]() ![]() ![]() |
Slowly fixing and adjusting.
Had to make slide spacer for bottom gathering chain tensioner as there was "none" on the left side. This is such a cool piece of equipment. So MANY chains, cogs, driveshafts, belts ETC. It reminds me of the old Gravely tractors. Safty was not a concern. The inboard chain guards are missing and when sitting in the driver's seat I feel I could loose an appendage at any moment ! |
![]() Crazy brake pedal position. After installing a picker the installer must cut and reposition the right brake pedal as shown. NEVER would I have dreamed. Edited by Macon Rounds - 19 Oct 2023 at 9:38pm |
tom51 ![]() Bronze Level Access ![]() ![]() Joined: 04 Apr 2019 Location: USA Points: 63 |
That break petal set up is all Allis Chalmers. Had to move the right brake petal because in the normal position it would hit the frame of the picker.
![]() In for more maintenance. Many MANY things need adjusted, tightened, ETC. Greased and oiled all the chains outside. Let the excess oil drip on the dirt driveway.... I had a suggestion to operate/pick some corn without the rear shoot attached. That sounds like a GOOD idea. Weather permitting we are just a few days out. |
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12007 |
OH BOY!! NEW TOY!!! Nice! Good luck with it!
Steve@B&B
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 8102 |
If I recall, nearly all mounted picker/shellers were made for 38” rows. Not sure if there were pull type picker/shellers made for narrow row corn? But would not be surprised if there were. |
Back in the day, unfortunately there were too many operators that severed a few digits attempting to unplug the machine while the pto was still in motion. |
Yep
We have 2 local guys here missing all but their thumb on one had.... The Allis pickers have ratchet type clutches. So you can hear them chattering when slipping. Many of the other pickers had disc clutches which are the silent diget eaters. |
tomstractorsandtoys ![]() Orange Level Access ![]() Joined: 11 Feb 2015 Location: wi Points: 515 |
I had the next to the last bid on one in Chambersburg PA this spring or early summer. Is this that picker? Looks nice and should fun to use.
