how strong are.... |
Page 12> |
| Author | ||
shameless dude
Topic: how strong are....Posted: 06 Sep 2023 at 6:42pm |
the screw type garage door openers?
| Sponsored Links | ||
Joined: 11 Sep 2009 Location: illinois Points: 90921 |
Posted: 06 Sep 2023 at 7:40pm |
"in general"........
How much weight can my garage door opener handle? For an automatic garage door, the lift of the weight is subject to the horsepower of the garage door opener. A half of horsepower can lift roughly around 300 pounds. This is the average load of a two-vehicle steel door, and a one horsepower door opener can, without much of a stretch, lift roughly 400 pounds.Nov 30, 2019 Edited by steve(ill) - 06 Sep 2023 at 7:40pm |
Posted: 06 Sep 2023 at 7:47pm |
another opinion.......
BELOW ARE THE AVERAGE WEIGHT LIMITS FOR MOST GARAGE DOOR OPENERS.The numbers are valid for Liftmaster, Chamberlain, Sears, Genie, and Linear garage door openers. 1/2 HP – Garage doors Up to 350 lbs. 3/4 HP – Garage Doors Up to 600 lbs. 1 HP – Garage Doors Up to 750 lbs. 1 HP+ For Garage Doors Over 750 lbs. |
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 06 Sep 2023 at 8:22pm |
I've installed a few Over-head Garage Door power operators. Per instructions the springs are adjusted to where it does take much to lift the door open. And if the power operator were disconnecded the door would fall closed without slamming. Or because of friction, stay where disconnected.
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25278 |
Posted: 06 Sep 2023 at 8:34pm |
just saw on TV... it takes just 10 HP to lift the roadways of the London Bridge......
shameless dude
Posted: 09 Sep 2023 at 12:13am |
thanks ya'll. I gotta do something for a man lift to put on my combine. the manufactured ones use the screw type for their lifts. they are over $5000. for one of their lifts. I can't afford that! my combines are not new and i'm sure i'll have to get in and out often during harvest season. tried a step ladder, that didn't work so well. been drawing up plans for several different styles. a couple look kinda crude...but if they work...works for me! any fabricators out there?
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3312 |
Posted: 09 Sep 2023 at 6:53am |
Dale, maybe consider using a cheap ATV winch. Harbor Freight used to have them under $100.
Posted: 09 Sep 2023 at 9:15am |
Dalel, what if you had a set of wooden steps and hand rail permanent mount to the ground / side of the shed/ etc... You pull the combine up within 3-4 feet of the top platform, then lower down a gang plank that is hinged to the combine platform , and walk over to the steps ? ......... or it could even be a LONG wheel chair type ramp ??
Posted: 09 Sep 2023 at 9:24am |
another idea would be to build a BOX like an elevator onto the side of the barn.. Use the harbor Freight winch or the garage door opener to move it up and down several feet from the ground up to cab level... pull up next to it and use the gang plank idea to get into the box.
Edited by steve(ill) - 09 Sep 2023 at 9:29am |
DanWi
Posted: 09 Sep 2023 at 3:34pm |
Neighbors dad has a wrecked shoulder so he couldn't climb the combine ladder. His son is a good fabricator so they made a stairway with handrail along side the combine. Only thing tall people have to watch so you don't hit your head on something. If your going to make an lift you can use a counter weight or gear reduction or a system of pulleys to make it easier to lift.
shameless dude
Posted: 09 Sep 2023 at 7:55pm |
thanks ya'll for the ideas, I also am drawing up plans using sliding shed door tracks and wheels, I think the HF winch would work good too as Trucker said, put a pulley on the existing steps at the top. will/can make a platform outta wood to stand on....I hope!
truckerfarmer
Posted: 09 Sep 2023 at 10:18pm |
Dale, I think you're onto something. Garage door track and rollers would make it simple.
Kenny L.
Posted: 10 Sep 2023 at 4:29am |
There is a company that make them for combine, the guy I help in the fall has one they're petty slick and will swing out when you need to work on thing that is behind them. |
DanWi
Posted: 10 Sep 2023 at 8:45am |
You need something that goes with the combine because at some point when you are out in the field you will have to get out and get down. Itherwise you are stranded and would need to call someone for help.
Kenny L.
Posted: 10 Sep 2023 at 4:33pm |
Here are some pictures of the ladder.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 14 Sep 2023 at 2:02pm |
Well, she used to be pretty strong, but as she's getting older, I have to get out and do it.
Dusty MI
Posted: 14 Sep 2023 at 3:12pm |
The springs are adjusted to where the door will pretty much stay where you leave it if it is a manually operated door, so the electric operator does not need to be very strong.
Ted J
Posted: 16 Sep 2023 at 4:12am |
What I was saying Dusty was; When I got home, I'd honk the horn and she'd come out and open the
garage door and then I'd take her in the house and screw her...... That's the screw type door opener!
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4284 |
Posted: 16 Sep 2023 at 7:40am |
Good one Ted!
shameless dude
Posted: 05 Oct 2023 at 11:42pm |
well...I've decided to build my own steps attached to the old steps of the combine. making them out of 2x6's and bolting and screwing it all together. I can pull myself up steps if they are closer together and not as steep. i've got most of the framework done and will start on the steps tomarrow hopefully. it's taking some time as I can't stand upright very long. i'm getting alot of sitting time as i ponder my next moves. had to have a tube put in one from tire and now see that that tire is dry rotted, couldn't tell that until we got the tube aired up! PfffffT! now I guess i'll hafta get a new tire, no one has used ones that size. I tried to get the local welding shop to make me a platform to stand on thus using the winch/barn door tracks, but he's about a year behind on his work! PfffffT!
Ted J
Posted: 06 Oct 2023 at 9:36pm |
Good luck Buddy. I hope you get it done to your satisfaction and it helps you out. I wanna see you at Hutch next year!!!!!
shameless dude
Posted: 09 Oct 2023 at 8:57pm |
well I got the frame made, sawed a couple steps before it turned dark on me. it's real slow going, trying to hold the boards and drilling for the bolts at the same time...my back doesn't allow me to stand but a couple of minutes at a time. sposed to rain here this week, still gotta tip the corn head on it's back so I can see what I gotta fix on that. maybe i'll put a tarp over it and still work on it while it's raining. also sucked trying to measure the wood since the machine is sitting on uneven ground. it'll be good enough for me! my corn isn't quite ready yet. bought a new fuel gauge for the tractors and combine today...a wood dowl! lol
shameless dude
Posted: 09 Oct 2023 at 9:01pm |
oh...I got the man lift info in the mail yesterday, requested it Sept 7th. looking at the pics, looks like they use a tube with the screw inside, powered by a motor that looks exactly like an electric jack on a camper. appears pretty simple, and wonder how they come up with a $5000 price tag!
iowallis
Joined: 04 Jun 2017 Location: North Iowa Points: 387 |
Posted: 10 Oct 2023 at 5:56am |
In this sue happy society probably part of the price is for some type of insurance in case somebody sues them. I am sure somewhere out there, even though the lift says "250 lb max cap." a 350 lb person will try using it, get hurt when it fails, and blame the company. Build something that a fool can use and a fool will find a way to get hurt using it.
Posted: 10 Oct 2023 at 6:12am |
how ??? cause PT Barnum was right !!!!
shameless dude
Posted: 11 Oct 2023 at 9:30pm |
gots one more step to make and i'll be done with the new steps, ran outta bolts and brackets to finish. sposed to rain tonight.
shameless dude
Posted: 20 Oct 2023 at 11:32pm |
the new steps is all done and it works GREAT! I can climb up to the cab and back down alot easier now. been trying to clean 8 years of grunge off the windows, has taken 2 rolls of paper towels so far! funny thing...there was a can of foamy glass cleaner in the cab...and it still works! didn't lose it's pressure inside the can, but the fire exquingisher has lost it's pressure! Wally World has the big ones, hopefully won't hafta use one!. a delivery driver that brought my new to me 6 row head thought the steps were awesum and he tried them out...smiled all the back to his truck. I sprayed all the wood with water repellant, and it's made so I can change the steps over to my other combine
iowallis
Posted: 21 Oct 2023 at 7:01am |
Word of caution, water repellent on wood can cause the rain/dew to bead up and make the wood slippery if this is what the steps are made out of. Maybe some spray adhesive with grit/sand thrown on or some no slip strips attached to the steps?
Ted J
Posted: 21 Oct 2023 at 10:44pm |
I tried the non slip strips, but they came off about a year later.
shameless dude
Posted: 22 Oct 2023 at 1:29am |
thanks for the reminder on the slippery steps...I have some of them non-slip things (I think what Ted is talking about) that is taking up room in my tool box, just as well use them. i'm real slow at walking up the steps, i'm sure if I slip & fall...it won't be very slow! now I gotta figger out steps for the back of the combine. tried clamping 2x4's on the rebar they used for steps...that didn't work! can't hang a step ladder back there, will gits beat to death by the spreaders. any suggestions?
Page 12> |
