roller pin removal
wlambs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wlambs Quote  Post ReplyReply Direct Link To This Post Topic: roller pin removal
    Posted: 01 Oct 2023 at 1:32pm
Tring  to get pin out of snaping roll on 238 corn head so i can replace needle bearing used punch and hammer got it to move very little any suggestions not sure whether to use heat on pin
185,6080,6060,72 allcrop, roto baler
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 2:17pm
Its been 30 years since I worked on one of those but it seems like those pins were tapered and only came out one way
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 2:19pm
If its a hollow pin thats not it. If its a solid pin its a possibility
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote wlambs Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 3:44pm
it is solid and tapered a little on one end
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 5:24pm
I meant its tapered thru the whole bore
If it is a tapered pin it will be smaller on one end than the other
Kind of hard to tell sometimes if it got bradded when it was driven in
1984 80780
1957 D14
616 tractor
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 6:11pm
238 orange? Or 238 black?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wlambs Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 7:29pm
black adjustable  row
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 7:28am
Gleaner Black Cornhead Parts book form 9004918, March 1977 lingo as follows:
POINT(cast cone shaped spiral?)
EXTENSION (cast transition behind needle bearing housing placed before blade set).
Try heating snapping roll point’s (spiral cone?)pin(groove 5/16”-2 1/8”)to cherry red then hammer/punch out? The last one I successfully hammered pin out without any heat, I used a stout 1/4" punch to move pin back & forth while applying penetrating oil onto/into pin & hole. That took time. Even had a helper manually wrench cornhead roll 180 degrees by using an open end wrench on hex drive shaft, as I stood between row frames.
Important note: If removing both rolls entirely per row, keep points/extensions properly matched.
LEFT POINT is long & is matched to a short extension.
RIGHT POINT is short & is matched to a long extension.
Needle bearing part # 560985
Needle seals(2), 560254
Edited by AC7060IL - 02 Oct 2023 at 7:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote wlambs Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2023 at 6:36am
thanks for answers heat and air chisel  worked good. was afraid to put heat on it at first
This page was generated in 0.184 seconds.
