Wheel weight bolts
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Topic: Wheel weight bolts
    Posted: 21 Sep 2023 at 7:37pm
My 185 has 18.4 X 30’s and I have a set of one piece Taylor weights to put on it. Will the bull gear housings keep me from installing the weight bolts or do I have to pull the wheel center off? TIA.
Edited by sparky - 21 Sep 2023 at 7:38pm
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 8:34pm
Not sure what taylor weights are but I think you can get bolts in if wheel is in right spot.  Also the width of wheel setting just to reach in there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 9:23pm
Spin out rims? If so spin them out and then you should definitely be able to get them on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2023 at 1:33pm
Yes it has spin outs. I’ll check it out more closely. I’ll probably yank the bull gear pans and change the gear oil. That should give me more clearance. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2023 at 1:54pm
Even spun all the way out I had to remove the tires/wheels on my D 17 to change the oil and replace the gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2023 at 2:01pm
Well if push comes to shove I’ll block her up and buzz the tire/wheel/center off and lay it down and mount up the weight and then yank the pans off. Sounds like a winter job in the shop is on the agenda. Thanks
This page was generated in 0.029 seconds.
