Busted wc block
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Busted wc block
    Posted: 19 Dec 2010 at 4:50pm
I started cleaning and powerwashing my unstyled wc today and found some welding behind the carb. It doesn't leak but it's ugly and I know it's there. What should I do? Is an unstyled wc block the same as a wd? Otherwise I had a great afternoon using my early Christmas present a new pressurewasher. The weather was in the low 50's so my wife let me have my present early. Hopefully I can clean a spot in the shop and get started on the restore.
Don Smith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Smith Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 5:11pm
If it aint leaking leave it alone!!! It wont hurt nothing it is a battle wound
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 5:51pm
Don's right...it won't hurt a thing,especially since it doesn't leak at all at this time. However,if you ever need one,I've got a couple of them that I would sell reasonable. They don't have any cracks between any of the cylinder sleeves or internally or externally. Rick
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 5:58pm
The 201 block is different in a WC compared to a WD...the WC has a side plate on the right side of the engine behind the magneto....WD's dont....at least the 45's dont....someone please correct me if Im wrong that WD blocks dont have it as well.....
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 6:00pm
wd blocks also have the plate it is the 45s and later that dont
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 6:01pm
Ya Benny, the WD had the plate too.
I am still confident of this;
Wait for the Lord;
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 6:02pm
Yep,the WC and the WD blocks are both 201 engines and do have the side plates on them.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 6:22pm
thanks for the correction....wasnt 100 percent sure but now I know.....
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 8:53pm
Unstiled WC blocks don't have the three 3/8 bolts along the right side of the block for head bolts. Other than the three bolts they are the same.  MACK
