Leaking lift cylinder
tom51 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Topic: Leaking lift cylinder
    Posted: 09 Sep 2023 at 11:07pm
Need some advice from the experts . I have a leaking lift cylinder on a WD that needs to have new packing installed. What’s the best way to proceed. Thanks
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 6:31am
Try just tightening the nut first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 8:48am
tom......... this will give you an idea..
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 8:25pm
Unscrew nut from rear of cylinder. Place a catch pan under cylinder. Raise lift lever to top, when old packing blows out, lower lever and arms. Remove rear cylinder pin, nut, old packing. Reassemble in reverse order.                   MACK
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 11:15pm
Packing nut was as tight as it would go no adjustment left. Thanks for the advice will order a packing kit and repack
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2023 at 8:07am
 Just offering advice but I would rebuild both cylinders. My luck would be the other cylinder would be soon to follow. I learned that lesson on a CA. I just recently rebuilt the cylinders on my 185.
Edited by sparky - 11 Sep 2023 at 8:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2023 at 8:38am
The last couple sets of packing I got for a cylinder, I got from Motion Industries. I don't think anywhere else can come close to the low cost they sell for.
 Motion Industries has a store finder on their website. Stores all over the US as far as I know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2023 at 1:05pm
If rams are like most....pitting and scoring make it hard for new packing to do its job.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2023 at 8:23pm
WD cylinders don't rust and pit like alot of cylinders because they seal to shaft not bore.                      MACK
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2023 at 11:30pm
Will do both cylinders rods are not pitted or rusty packing ordered today. Thank you for all your help
This page was generated in 0.283 seconds.
