Roast Beef recipies,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Roast Beef recipies,,
    Posted: 06 Sep 2023 at 6:29pm
What everyones ways to make tender roast beef ?  Church picnics and now Fall Festivals always have the best,,  trying to find the secrets!!
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2023 at 9:14pm
Crock pot. Low and slow.
Edited by truckerfarmer - 06 Sep 2023 at 9:15pm
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2023 at 9:39pm
rub it with seasonings and smoke
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2023 at 7:11am
another vote for low and slow ...crock pot or whatever method you can do the same low temp and longer cooking time.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2023 at 11:12pm
Years, and years ago, Mom would buy what was then called ‘chuck roast’, back in the day it was about the cheapest cut of beef available. Cooked slow, in one of those dark blue/black porcelain baking pots w/lid. Couple cups of water, and a package of dried soup mix sprinkled over the meat. 4 hours or so in an oven, lowest heat setting 150 degrees?
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 3:01pm
I'm not a cook and don't plan on being one, but my wife (learned from my MIL) places a roast beef in the oven at a very high temp searing the outside.  After a certain time, turns it down and slow cooks with the carrots and potatoes.  Searing it seals in the juices and it is darn good
D17 Series 1
Allis B- 1939
Allis B- 1945
NDBirdman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 6:55pm
I usually sear in hot pan on each side before putting in crock pot.  Keeps it fairly moist but it is pretty easy to leave in pot too long and dry it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 7:04pm
Ive tried the crockpot- on low for 8 hours , water- juices in it. after 2 hours its already done ,, and tough, bought another pot ,, same deal , cant figure what is going on,, we put deer meat in a black kettle years ago under a fire,, dam that was good eating !
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 11:38pm
try putting in Dr Pepper instead of water in your crock pot, always low and slow, same low and slow ina smoker. I have used Sunkist orange soda in the crock pot and it turned out very well...have to use the Sunkist brand...not any orange soda will do. if you use an outside grill, put ona spit and let it cook slow, there you will want to use your favorate seasonings, rub it in good, and cook til it's blackened on the outside, will be tender on the inside. look up vids on you tube on the BBQ Pit Boys, they show alot of different ways to do it and what type meats to use, usually they also use a cheaper cut of meats. they like hot spicy stuff, you can adjust that out. I like watching them cook about anything...it's good entertainment! If you don't have a spit, don't use your battery drill, it'll burn it out, not from the heat of the grill...but from the slow setting to turn the spit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2023 at 1:47pm
Thank you!!!!! Will check it out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 2:32pm
Of course it all depends on the cut of beef and the weight, but slow and low.  I use 250 for 4 to 6 hours and check halfway through so it's not dried out.  I've also used Dr. Pepper and it works great.  I tried coke one time and the whole thing just fell apart.  Wasn't worth spit.
LOTS of onions, mushrooms, baby carrots and spuds (preferably red) with the skins on.  Cornstarch for a thicker gravy....YUMM!!!  Dang, and I'm having a taco salad for supper tonight.
