Wd45 power steering leak
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 power steering leak
    Posted: 31 Aug 2023 at 11:51am
Hi a’ll!!
So I’m getting really tired of this power steering leak and can’t figure out how to fix it…
I’ve replaced the O-ring but it helps for awhile than it leaks all over again…
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2023 at 12:40pm
I'd scrape all that paint off both surfaces, run a flat file on each side (unless both sides are "somewhat" flat), and use a touch of rtv silicone in the o-ring groove.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2023 at 9:32pm
The boring under cap is only a dust seal. There is orings on spool that need replaced.                        MACK
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2023 at 6:38am
Look at the barrel when you have the spool out. Water will form pits and the o-rings will not seal.
http://lonsallischalmers.com
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2023 at 7:39am
I had the same problem. Mine would leak oil while it was not running. I did everything I could think of twice. Finally, I noticed the cap was slightly sprung or warped. I straightened it that stopped the leak. Good luck, this kind of problem can drive you nuts.
D-12III, 200D, 170G, HD-3, D19D 3pt, D17D High Crop, WD45G p/s, D15IID, D15IIG, D15G IND, 655, (3)WD45D p/s, 700, 816
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2023 at 10:34am
Thanks Mack!!!
I didn’t even know there was O-rings there….
I replaced the O-rings and it works like a good Allis should!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2023 at 10:37am
It doesn’t have anything in there to catch my finger nail on and no rust in there (it surprised me) so I think it’s ready to roll!!!
This page was generated in 0.285 seconds.
