Should I be concerned?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: Should I be concerned?
    Posted: 28 Aug 2023 at 9:00pm
Im putting my D17 diesel back together and as I put my belts on I noticed how close the fan blade comes to the air cleaner. The air cleaner bolts to the head so it’s not like I can move it. I guess I didn’t notice this before because the fan blade wasn’t in this position before when I took it apart. Looks like a 1/8” clearance. Anyone out there that has a series 1 diesel mind taking a glance and let me know what they see?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 9:01pm
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 9:12am
Are all the blades showing the same clearance?  Maybe a bent fan blade if they are not.
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 1:10pm
Is there an outside chance that the fan on backwards, and the offset has the blades closer to the canister.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 1:20pm
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 1:53pm
My bad Steve, I didn't spend enough time studying the photo and thinking of what way the engine rotated. Had brain fog I guess
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 2:34pm
If you put it back like it was it must have been that way before. Clearance means it's not touching! Lol. The blade should flex fwd in use if anything. Where's your faith?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 4:32pm
looks like a spacer plate might be a good idea !! ..... be nice to have 1/4 inch clearance.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 5:16pm
Does look very close. Or is it camera angle? Was there a spacer under it? Maybe was lost over the years.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 7:32pm
Fan appears to on backwards. Engine rotation is clockwise if I’m not mistaken.
RickSoKansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickSoKansas Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 7:57pm
The picture looks like mine, about the same clearance between the fan and the air cleaner, the fan is the same as mine. Been that way for years.       Rick
D17 Diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2023 at 8:49am
Thanks Rick for looking at yours. I did verify all blades are the same gap when I rotated the fan. So, I will feel better knowing it is correct.
Appreciate everyone for their input.
Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2023 at 12:17pm
After a few months of being dismantled for repairs, new paint, new wiring harness, pump work, I fired her back up yesterday. No issue at the clearance of the fan and breather. Fan ran straight and true. Just really surprised at how close it is and that I did not notice it before.
This page was generated in 0.230 seconds.
