CA vs C
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: CA vs C
    Posted: 28 Aug 2023 at 4:23pm
What's the difference between the two? One's a 3 speed and one's a 4 ? Just wondering. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 4:37pm
CA is a 4 speed, spin out rear wheels , better hydraulic pump , slightly heavier rear axle housings...........
basically same engine , radiator, sheetmetal, tires... CA is a "newer model" of the C.
a lot of the parts can be installed between the two as assemblies.
Edited by steve(ill) - 28 Aug 2023 at 4:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 4:48pm
Don't forget the CA has pto that will spin while the tractor slows or stops.  Not exactly live pto, but much improved over the C...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 4:57pm
Thanks Steve and Dave
I see both on marketplace pretty often.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 5:56pm
as DAVE said, the CA has a hand clutch on one rear axle to disengage travel while maintaining the main clutch drive thru to the PTO shaft... Thats an advantage... but 90% of the ones you buy WILL NOT WORK after 60 years... Most need rebuilt.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 6:33pm
If your agility has diminished such as mine has, the C (and B) with the flat seat and backrest is fairly difficult to mount and dismount; the CA has a pan seat without the back rest and is somewhat easier for the aged and infirm Smile
Edited by Les Kerf - 28 Aug 2023 at 6:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 7:01pm
I hear ya , Les . My old D 15 is easy to climb up on . Especially with the nice step I bought from the guy on this site . Thanks !
Dale (Stonelick) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 11:18am
I think of 10 improvements (1) HP, (2) hydraulics, (3) 4 speed trans, (4) heavier axle, (5) draft control, (6) seat shock, (7) hitch, (8) hand clutch [Rick rebuilt mine], (9) live PTO, and (10) spin out rear wheels.
1951 CA - 1944 C - 1949 B - Kubota M6800
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 11:43am
CA also has an increase in horsepower of about 11% over the C.  They increased the compression ratio to 6.25:1 and increased the max RPM (don't know what else).  This in part to enable support for a 2-bottom plow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 11:54am
Gary , that was part of my confusion . I thought they were both 18 HP ? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 12:29pm
Higher compression pistons and different governor spring to increase the RPM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 12:58pm
After 70 years, most of them have probably been rebuilt with an "overbore" kit.  That can further increase HP from about 26 stock to about 29, nearly equal to a stock WD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 2:06pm
Thanks guys.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2023 at 6:55pm
My Father said the CA was the perfect tractor for the Roto-Baler. Just enough hp to notice the engine sound change as the hay condition changed during the day. Dad said a trained ear would know when the baler needed adjustment, by listening to the engine.
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2023 at 7:12pm
I’ve owned 7 CA’s and have 3 now. Just my opinion but pound for pound I believe that the CA’s were the strongest tractors Allis ever built.
