CA Roll Bar? |
dfwallis ![]() Orange Level ![]() Joined: 09 Mar 2023 Location: DFW Points: 863 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Aug 2023 at 3:56pm |
Has anybody ever added a roll bar (and/or associated canopy) to a CA? Where would you attach it?
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88402 |
does not answer your question.. but here is the actual testing on a Allis 190.
DSpears N IL ![]() Silver Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Rockford,Ill Points: 415 |
I had a square steel tubing frame and 2” angle iron bottom bolted to the platform rails inside of where the fenders are mounted.
Then got a fiberglass canopy from a golf cart for the top. Do not have it anymore. Definitely Not a Roll over protection device! DeWayne ![]() |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22087 |
If you're wanting roll over protection, attach to the axle. If you want a sun shade...the fenders would work for that.
I was thinking that I could attach to my new drawbar supports that I'm making that attach to the cultivator brackets on the axles. But they would have to bend to follow the shape of the fenders and might limit how far in the wheels can shift. My new hydraulic remotes will be attached to the inside of the fender rails positioned vertically, I'm hoping. Need to make some more measurements.
Edited by dfwallis - 19 Aug 2023 at 12:21pm |
Cool, that looks fine...
