marvel schebler
lost in h3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Topic: marvel schebler
    Posted: 04 Aug 2023 at 9:37pm
My h3 has a marvel schebler carburator which is a TSX879. I need a complete kit plus both shafts and choke butterfly. Does anyone know what kit will work with this? No one has a kit for a TSX879. Would a TSX878 WORK?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 6:43am
Don't know where you have been looking but here are a few possibilities.  Most kits won't have the hard parts (shafts and choke butterfly) you are looking for.  Standard Motor Products shows the TSX879 for an H3.  Their kit number for it is 1302.  Steve at B&B Custom Circuits rebuilds carbs and can likely help you with the parts.  McDonald Carb and Ignition likely has a kit and hard parts.  There are many others.
Edited by Jim.ME - 05 Aug 2023 at 6:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 7:14am
Do you know what part numbers are for the hard parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 7:36pm
A WD-45 carb is almost identical to a D-15 series 2 G-160 engine. Throttle shaft is different but the WD45 shaft could be modified to work. Choke plate is the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 9:07pm
226453 choke plate
226445 says use 231437
Edited by Mikez - 05 Aug 2023 at 9:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 9:54pm
Mikes
Do you think a wd45 carb kit would work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 10:15pm
Dr said there similar
Those are from a wd-45 parts book.
