Hydraulic hose placement
Jhilton69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic hose placement
    Posted: 01 Aug 2023 at 9:40pm
I blew a hydraulic hose on my AC 1962 HD6G last week and somehow got 2 of them backwards. Can someone help me get them the right way. It's the left side of the loader(driverside). There the ones that are located on the bottom back under the seat. Pics and which ones go where would help a lot. Thank ya
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2023 at 10:41pm
   Where did you disconnect/ reconnect them? Under the seat at the tank, or under the guard in front of the battery box?
Semper Fi USMC    1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2023 at 11:03pm
I reconnected them back under the seat where it has 2 stacked on top each other
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2023 at 11:53pm
I can't look at mine until tomorrow. There are tw0 different setups, a break at about serial number 11000, and the diagrams in the parts manual are difficult to visualize, with all the pipes stacked and running so close together.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2023 at 5:23am
Not knowing serial number of tractor limits accuracy but here is a diagram of an HD6G which may help:
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2023 at 7:51am
The hydraulic fluid tank diagram shows these ports pretty well, but I can't get pictures to load here. Looking from the outside, the upper right of the 4 ports is the retract tube of the left dump cylinder, the lower right port is the dump port for the left dump cyl. Upper left port is for the boom cylinder raise, and the lower left port is for the boom cyl lower (retract).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2023 at 4:20pm
Thank you this gives me a good idea where to start. Glad you could follow the lines I tried several times and got lost when they hit the connection in the middle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2023 at 4:22pm
It's a 1962 model the places it says the serial number is it worn off
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2023 at 6:01pm
These are the 2 plates that's supposed to have the serial numbers I see 1 of the numbers looks like it's on both plates. Is this the serial number
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2023 at 8:42pm
Looks like 23xxx, so it is post split. Hoses go to same hydraulic tank ports on both early and late models
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2023 at 11:57pm
Thank ya
Bob_T View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob_T Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 11:23pm
I did the same darn thing.  In a hurry, I didn't mark them because I thought they'd only fit and connect one way.  Wrong! The image won't load but I'll see what I can do using doctorcorey's text description.  Thank you!
This page was generated in 0.207 seconds.
