180D orchard
wildcat2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildcat2 Quote  Post ReplyReply Direct Link To This Post Topic: 180D orchard
    Posted: 08 Jul 2023 at 9:11am
Theres an interesting 180D on Hibid.  Mulrooney Auction Co. has it.  Was there a orchard 180 made or is this a home one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2023 at 9:38am
https://hibid.com/lot/162306687/allis-chalmers-180-tractor-s-n-180-3141-d?ref=lot-list
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2023 at 10:29pm
Looks like it might have rotated final drives??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2023 at 11:47pm
Well that’s interesting looking
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 8:09am
I have a pair of wheel weights that came off a 180 or possibly a 185 that had fenders like that. It was in the 'yard' at Colfax tractor, not sure if it's still there or not. Maybe I'll run over and have a look later today.
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 9:32am
I don't see the power director lever or pto lever
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 9:55am
front axle has obviously been modified.. Original had DROP king pins ... photo shows the axle TUBE about centered in the wheel / hub.
stock 180 front axle
Edited by steve(ill) - 09 Jul 2023 at 9:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2023 at 8:50am
Found a picture on my phone. One at Colfax is a 185.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2023 at 8:55am
I think the final drives must be rotated forward one hole to lower it down in the rear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2023 at 8:56am
Steve I believe they flip spindles upside down.
Are these rare. Iv never seen them around. But you don’t see them in to many collections
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2023 at 9:00am
The picture I posted is at least five years old, not sure if that tractor is still there or not. This discussion has me curious. If I can just get free for a few to go have a look. Dr.'s thought about rotating the finals forward is leading my curiosity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2023 at 9:40am
I think those front five weights are from a J.I. Case tractor ??  not Allis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2023 at 9:45am
Is the muffler hole in hood blocked off.
Was there anything stamped into sr no for orchard tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2023 at 11:02am
Mike... i think your on to something... If you pull the Square Tube axle out of each side and flip it... it kind of looks like your photo above... that should drop it a few inches..
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2023 at 11:09am
Would not surprise me if there was a shop out here in California that did more than just 1 or 2 of those one 180's. Look at the much newer CaseIH just behind it, I believe that cab and limb lifters was a California made as well. A million acres of almonds need lots of tractors, not counting peaches, plums, pears, apples, pistachios, and cherries.
But a larger farm with lots of cheap help, can make expensive tractor maintenance. Which leads to a short life for many tractors out here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2023 at 2:59pm
From reliable sources, the factory built very few dedicated orchard models.  Something like this would have been converted by dealers in the California area.  While AC may have provided parts for these conversions, they are not factory made orchard tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2023 at 9:10am
Doc, I'm not sure what they are. Looking at them they almost look like Oliver weights but maybe not quite. I've seen the Case weights you mention, not sure if that's right either? It would be nice if there were a Brian Ahart type site for each brand. If you look closely you can see the wheel weights I took off in the edges of the picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2023 at 10:15am
I have a White with one or two of those type weights. But a flame cut piece of 3 inch plate was added in front of the factor weigh. So I have never seen the front side of the factor weight. So the Oliver idea sounds very possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2023 at 2:55pm
I see an original cast iron A-C wrap-around starter weight (approx 250 lbs) bolted to the front of the tractor. Then I see FIVE identical weights attached to the starter weight. Nothing flame cut. ALL cast iron. Oliver does sound better than what I thought was J.I. Case.
Edited by DrAllis - 13 Jul 2023 at 2:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2023 at 3:44pm
closeup
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2023 at 4:07pm
That is a whole lotta weight on the front of a 185 tractor !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2023 at 8:34pm
Interesting 3pt setup
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2023 at 8:44pm
Wow the top lift arms don’t match
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2023 at 8:46am
After looking at some Oliver slab weights on you tube, going to say they are Not Oliver. Still curious what they really are.
Artfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Artfarm Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2023 at 6:16pm
Those weights are Allis Chalmers industrial like used on the rear of an HD-4 crawler loader.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2023 at 6:41pm
I have a D17 diesel from California that has been lowered and the final drives rotated like this 185. Showed a picture to the late Norm Swinford who in my opinion was the ultimate authority on all things AC. He said that none left the factory that way, Large dealers in California would modify a new tractor to the customer's specs. A lot were J&M conversions. There was a nice 185 like this at the Nesbit sale in 2017. Friend bought it and modified it back to a regular farm tractor.
Edited by Calvin Schmidt - 14 Jul 2023 at 6:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2023 at 8:57pm
I’m trying to figure out the 3 pt. Not sure why the left side needed a hydraulic cylinder to raise and lower that side? Not sure what equipment would need to be raised or lowered on just one side?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2023 at 9:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2023 at 8:33am
Thanks.
The cylinder on the three point is interesting. Would give some added adjust-ability.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2023 at 11:40am
Very possibly a blade to put up a boarder for flood irrigation. Back in the day of a 180 all most all tree crops would have been flood irrigated. I have never used irrigation but the boarders or checks as I learned of them could be removed for some operations. Then a pass or 2 and it is back to run more water.
