wc to wd 45 diesel flywheels weights |
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3480 |
Posted: 11 Jun 2023 at 4:15pm |
any certian one wieght more than the others
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3362 |
I’m way outside my lane on this but that 45 diesel flywheel is damn heavy. More than the 170 I have. But isn’t the rear main seal on the diesel different than the others?
Orange Level Access Joined: 12 Sep 2009 Points: 20149 |
The diesel flywheel as it is won't fit on a W-201/226 or G-226. Six holes instead of four and the rear seal sleeve is part of the flywheel, which could be machined off. Getting the four to six hole thing figured out could be a challenge. I have added 11 extra pounds to the gas flywheel used in a WC/WD chassis. Don't know how close that gets it to a diesel flywheel weight.
D17IV
Bronze Level Joined: 06 Oct 2009 Location: Ohio Points: 102 |
They are heavier, but machine work is required to remove oil seal flange, countersink and fix the bolt pattern. I recall the gas vs. diesel ring gears are the same, however you will find they are in a different location on the flywheel; so that will also need addressed.
B110, 1937 WC, CA, 2-WD45 Diesels, D14, 2-D15 Series II and 2-D17IV
HudCo
i am going try to get the doner parts out of a wd this week and see what part of the wc flywheel i can use on the wd flywheel hope that makes sense . but may be machining a diesel wheel would be cheaper in the end , but i have to stick to the dr.s budget biuld if i want to get a pull out of it this year
