301 crankshaft |
soggybottomboy ![]() Silver Level Access ![]() Joined: 20 Feb 2018 Location: Iowa Points: 218 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Jun 2023 at 12:51pm |
I have a crankshaft out of an Allis 301 diesel. I haven't had it speced out yet. If it turns out to be in good shape, what is it worth? The opinions so far range from $200 to $1500.
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 966 |
There's at least 2 cranks for 301 CID engines. Knowing it's part number or what engine model number & serial number may help determine the value.
Narrow gear or wide? MACK
It's out of an M2 combine engine. The serial # was hard to read, but looked like 109 thousand something. I don't know the difference between narrow and wide gears.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22021 |
First M-2 was 1977, so it would have the wide gear to be able to drive the crankshaft driven oil pump used first on the 200 tractor and later.
