7030 clutch |
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2609 |
Topic: 7030 clutchPosted: 31 May 2023 at 1:08pm |
My son says he has to shut engine off to put trans in gear we are baling. Easy adjustment? Thsnks Dana
Blue Skies and Tail Winds
Dana |
captaindana
Posted: 31 May 2023 at 1:37pm |
More info we just met both baling and its the trans brake how do i adjust? The engine clutch is good and he said he can live with it throughout today. Just started this issue today
Dana |
Posted: 31 May 2023 at 3:22pm |
Engine off. Stand outside an open cab door. With your hand there should be ZERO free-play in the clutch pedal. Chances are good you have free-play because the two brass bushings on the clutch valve spool fork are broken. I suspect you'll need two- 70269529 bushings from AGCO and adjust the cable to zero free-play. Spray WD40 all over anything that moves.
captaindana
Posted: 31 May 2023 at 5:50pm |
Yes Doc I believe 3 plus inches of pedal free play Thank you!
Dana |
Posted: 31 May 2023 at 5:55pm |
The maroon side panel down from the clutch pedal needs to be removed after rolling back the floor mat. Five bolts I think.
captaindana
Posted: 31 May 2023 at 6:23pm |
OK Doc I just checked it engine off door open. There’s only an inch at the most of FreePlay can I just get in there and tighten that cable after removing side panel? Thank you so much!
Dana |
captaindana
Posted: 31 May 2023 at 6:27pm |
I guess once I get in there in the morning, I can tell more! thank you
Dana |
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1128 |
It’s not a cable adjustment if bushings are broken
Posted: 31 May 2023 at 7:36pm |
You can try the cable adjust without removing the panel, but my $$$$ says it needs bushings.
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2235 |
Posted: 01 Jun 2023 at 7:55am |
My 7060 did the same thing. My problem wound up being the cable going from clutch pedal to valve. The exterior of the cable had come apart and the actual inner part of the cable was protruding through and I wasn't getting a full stroke with the clutch pedal. Just another thing you may look at.
Leon B |
captaindana
Posted: 01 Jun 2023 at 2:19pm |
Wow as usual Doc was spot on with the broken / worn bushings which are on their way. Leon B my cable is exactly as you say yours was and is on the way. I don’t know how to get to the top end oh the cable ?? It disappears into a dark hole Dana
Dana |
Leon B MO
Posted: 01 Jun 2023 at 2:43pm |
If you're 7030 is set up like my 7060, I took the bracket off that the cable attaches to at the pedal end of cable, 2 3/8 bolts then the clamp can be worked on much easier. I did remove both upper and lower panels.
Leon B |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5284 |
Posted: 01 Jun 2023 at 3:04pm |
Just think how much faster you would have had things back doing what they should have if you had read the manual to do some preventive maintenance over the winter.
captaindana
Posted: 01 Jun 2023 at 6:13pm |
I hear ya Paul, why did I convert 8 6v systems last winter? My new heated shop is too small for the 7000 series and on top of that I bought several beautiful 7 grand series in the past 2 years. I will eventually catch up on their needs. Honestly caring for 24 has been an eye opener🙄
Dana |
