h3 engine
lost in h3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Topic: h3 engine
    Posted: 09 May 2023 at 1:31pm
My h3 with early serial number appears to have a 160 engine instead of the 149. Did they put a160ci engine in h3 or is this a transplant
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2023 at 4:06pm
Later H3s used the 160, but it's basically the same as the 149 engine.  Over 60 years, a lot can happen to a crawler or tractor.  An engine transplant like this would not be unusual.  The D15 Series 2 tractor and some off road forklifts used the 160 engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2023 at 4:57pm
Thank You
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2023 at 5:16am
Link to website Tractordata for H3 Info: including Serial Nos.
https://www.tractordata.com/farm-tractors/007/9/8/7981-allis-chalmers-h3.html
The 160 cu.in. Engine started in the D-15 in 1963.
G
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2023 at 7:00pm
H-3 Crawler Serial Number from start of production to mid 1962 utilized a G-149 engine.  After that the G-160 was used in the H-3.
Orangeman
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 2:11pm
Decades ago I had a H3 loader/backhoe. I was developing a small downhill ski area that would require a snowmaking system thus the need for a backhoe and slopes that required a crawler. There was a JD dozer/backhoe available at the same time but the AC was about 1/2 the price.  The AC needed the tracks rebuilt but would be still less than the JD and would be confident that with rebuilt tracks I shouldn't have problems with losing a track on the slopes. The hoe was mounted in such a way that you could drop the hoe or reattach it in about 10 minutes so that you were not carrying the hoe around when it was not needed. Never ever had engine problems.
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 4:40pm
The Red Power thread is reporting "contact"
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 9:11pm
I have no idea what red power is or contact.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 9:26pm
Red Power is another website like this one for IH tractors. Many of the same issues with communication mimic your problem and they are getting resolution as far as communication.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 4:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 7:15am
With many of these internet vendors, they do not have stock on anything at all. They are in an office cubical and only route orders to several places sourcing parts for an order from a database. It is why there can be such problems when errors occur as there can be several sub vendors to the original order. No real way to go to a single source solution especially when an order is placed incorrect. Sometimes it works out, sometimes not.
The "lowest price" shopping point is not always the best approach IMO.
That's All Folks!
