Penetrating Oil |
Author | ||
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
![]() ![]() ![]() ![]() ![]() Posted: 15 May 2023 at 3:20pm |
Maybe 60 years ago I bought a can of penetrating oil, Rust Aid by Detroit Efficiency Company. That was the best I had ever had, and have never found any sense of the same. What is the best can be bought today ?
Dusty
Sponsored Links | ||
Darwin W. Kurtz ![]() Orange Level ![]() Joined: 06 Apr 2010 Location: Westphalia, KS Points: 4966 |
make your own with 1/2 automatic trans fluid and 1/2 paint thinner. A salvage yard man told me they had freed stuck motors with this combination
KMAG ![]() Orange Level Access ![]() Joined: 26 May 2020 Location: Elizabethtown, Points: 680 |
While not as good as atf/acetone mix, Kroil works well. PB Blaster is a distant 3rd.
WD40 is around 80th place. |
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12234 |
Yeah, WD 40 smells kinda good, and it ends there. |
Jgranat ![]() Bronze Level ![]() Joined: 25 Mar 2019 Location: NW PA Points: 131 |
WD40 is a rust preventative, not a penetrating oil. I like blaster, but I think heat penetrates the best.
I use JB 80 here. seems to beat out other penatrants. don't take much to work.
Dirt Farmer ![]() Silver Level Access ![]() Joined: 15 Sep 2020 Location: Illinois Points: 442 |
CRC makes a product called Knock er Loose. You can get it at most auto parts stores, bad thing with it is that once you start using the can the spray pressure disappears in about a month then you have to squeeze the can to continue using it but works great and not bad smelling. There is also a product called freeze off that CRC makes that works good too, it uses a penetrating oil and extremely cold air in a can to loosen stuff
klinemar ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Michigan Points: 8060 |
Here is a video of Penetrating Oil testing.https://youtu.be/xUEob2oAKVs |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24735 |
In the beginning....the first 39 tries to make a 'displacer of water' failed.... then WD40 was created. While WD40 does have it's uses, it's NOT a very good 'penetrating oil',as tests have told.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5146 |
The answer to this is: "To each his own" I've had some thing stuck that KRIOL won't budge, others moved with PB Blaster. Right now I have a hub stuck on a MM U that nothing is working, home brews included.
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9955 |
I have a friend who swears by iodine. Have not tried it myself.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54315 |
I think you have it right, there. If its something unere about 1-1/4" I use this lil beauty: Note, you don't have to heat to red, heat just long enough to get it smoking... And, as shown in the vid, you can still snap off stuff. I generally use a small impact, set to tighten, then to loosen, after the heating...
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8367 |
In my opinion, there all about the same- just a little oil lube in a simple spray can, we got that kroil at work - expensive,,
Is that really worth a winky face? |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3939 |
my new thing is free all , i have been using that for about a year or two ithink its the best rust buster penitrating oil i have ever used but much for lubricating . the better lubricating penatrating oil that i have useing is shaffers pentro90 . istill use texas refineries essental lube for penitrating oil when i am heating parts with the torch it really thats alot of heat
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34357 |
This can I got at an auction, Nut and bolt loosener, and it really did loosen stuff but sadly, I can't find anything about who sold the stuff ormade it other than PRESTO is on the can. wish I could find another can of that stuff. ![]() It sure beat everything I have tried lately.
I do like WD40 because of the straw feature on the can. As for best product, I don't really care! In some situations any lubricant would work. In other situations your using a cut off wheel or the "Hot Wrench"!
iowallis ![]() Silver Level ![]() Joined: 04 Jun 2017 Location: North Iowa Points: 375 |
At work the maintenance mechanics use this stuff, haven't tried it myself. As a joke when one of them got married (and mentioned starting a family) on his can on his cart they taped over the "loose" and put "up". Most times I use the 50/50 mix. Have a can of Kroil for extreme cases as that stuff is expensive. Bought a can of Free All to take to the salvage yard but can't say how it would work on an extremely rusted/stuck bolt/nut.
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3571 |
Definitely add heat for toughest items. If possible, try to heat the item that you’d like to expand. If you can’t expand the ideal part, then Heat will transfer very well on attaching part(s). One time I was able to successfully remove a corroded semi truck’s engine starter mount bolt by heating the bolt’s head(only piece I could access with torch heat). It was a Steel bolt threaded into an aluminum transmission bell housing ~ so decades of corrosion between different metals. Took two heat cycles(dull red color). Heat up, let cool, do again. |
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 3034 |
For those of us without a welder or torch is there any handheld propane style torch that will get hot enough ? Thanks
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8655 |
I think the MAP gas torches produce more heat.
Thanks Steve ! I'll check them out .
This link explains MAPP Gas. To get a heat hot enough Oxygen is required. https://en.wikipedia.org/wiki/MAPP_gas
Thanks Mark!
Walker ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: oh Points: 8984 |
I thought WD 40 is a moisture displacement. Try 50% ATF, 50% Acetone, season to taste, heavily slather on some brake fluid, again season to taste, and let her rip. The acetone will evaporate quickly, so act accordingly. Pour it in the toilet if stomach pains occur. See a Doctor either Jill or Kamala if erections last more than 4 hours. Should you land nose first get it as hot as you can and melt a candle on it.
D19allisowner ![]() Orange Level Access ![]() ![]() Joined: 12 Dec 2011 Location: NE IA Points: 3076 |
If you choose not to decide you still have made a choice.
Thanks Jim . That would be nice to have !
