D-10 series III |
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
![]() ![]() ![]() ![]() ![]() Posted: 15 May 2023 at 10:45am |
How do you get the the Steering Ball Joint out/off the Steering Arm? I know that it's a tapered fit. I've supported the arm from the floor, and backed the nut off to the end of the tampered bolt, and hit it with a heavy hammer. Maybe I should heat it.
Thanks, Dusty
TramwayGuy ![]() Orange Level Access ![]() Joined: 19 Jan 2010 Location: Northern NY Points: 11772 |
With something like this:
https://www.autozone.com/loan-a-tools/loaner-tie-rod-end-puller/p/oemtools-tie-rod-end-remover/409628_0_0 And you can rent it instead of buying. Edited by TramwayGuy - 15 May 2023 at 10:48am |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88320 |
Sometimes hitting the steering arm on the side of the HOLE will shock load it and let the taper shaft loosen up....
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10826 |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8658 |
Backup BIG hammer on one side and smaller hammer whacking the other. Where i can fit it I use 8lb sledge and 4lb hammer.
