Wd endless belt cover
BigJon1_WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigJon1_WI Quote  Post ReplyReply Direct Link To This Post Topic: Wd endless belt cover
    Posted: 12 May 2023 at 6:08am
I picked up a mid mount 4 row cultivator for my Wd. Only problem is it had a endless belt pulley mounted on it. Rather than trying to find the press in cup, can I just put some permatex on a piece of metal and bolt it over the hole?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 6:29am
You can and it will leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigJon1_WI Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 6:35am
Awesome. Time to go scrap yard hunting. So much for trying to do it the easy way.   Thanks.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 7:16am
Prior to S/n 10595 they used a gasket and bolt on cover after that they used 70202289 seal 20.09 and 70224514 push in cover 95.94 AGCO still has them
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 8:40am
how about a trailer axle grease cap ?  what is the bore size ?
Edited by steve(ill) - 12 May 2023 at 8:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 12:30pm
I have the proper plug that I will sell. Send me a PM if your still looking for one
Owner of Matt Scott LLC
http://www.mattscottllc.com/
