7020 tac playing tricks
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: 7020 tac playing tricks
    Posted: 25 Apr 2023 at 7:32pm
The tach on my 7020 started a new trick this year. I will start the tractor and the tac will work for about 5 minutes then nothing. It's done this three times this year. Last year about every other time I used the tractor I would start the tractor the tac wouldn't work for the first few minutes then it was like a light switch and it would work and stay working. Is there a pickup sensor somewhere that's finally given out? Thanks
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 8:57pm
First thing, tighten fan belt. If  alt. pulley is Shiney in the bottom, replace pulley and belts.                  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 9:28pm
Luke, the tach gets its signal from an output on the alternator...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 9:32pm
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2023 at 8:42am
I had something similar years ago on a 7000 and a 7020.  Wasn't long after playing that trick that it needed a new alternator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2023 at 9:20pm
Belts are tight doesn't change it all wire connections are tight on the altinator
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2023 at 8:10am
My 7020 did that and it was the alternator going bad.
'59 D14 '68 170 Diesel '81 7020 40 All Crop
This page was generated in 0.111 seconds.
