D17 series III leak??
BTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BTR Quote  Post ReplyReply Direct Link To This Post Topic: D17 series III leak??
    Posted: 20 Apr 2023 at 10:39am
I have a leak and I am trying to upload a picture to see if someone can help me identify how to fix this issue.
BTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BTR Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 10:48am
Can someone please tell me how I can upload an image?  So much easier than trying to explain where the leak is coming from.
BTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BTR Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 11:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 2:27pm
Missing drive-in plug. Shaped like a disc blade.
BTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BTR Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 4:37pm
Would you happen to have a picture of what it looks like, so I can order one?  Thank you for the information.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 5:17pm
70229579 plug from AGCO. I have no idea if it is still available.
BTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BTR Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 5:56pm
Thank you so much.  I will check and see if I can find one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 7:29pm
they are called Welch plugs or Freeze plugs .. used to plug casting holes in engines coolant and oil systems.. If you know the diameter you need, you could go to NAPA and get one... Buy a couple different sizes if you need.
example---
Edited by steve(ill) - 20 Apr 2023 at 7:32pm
BTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BTR Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 7:58pm
Thank you so much.  What a huge help!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 8:01pm
McMaster Carr catalog.... size chart..
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2023 at 2:58am
Notice that the expansion plug is different from the Welch plug...  The Welch has a rim.
The expansion plug does not.  It is round, but no rim... instead, it has a formed depression in the center.  To install the expansion plug, you clean the hole out well (carb cleaner, toothbrush, a pick, and some paper towels) place the high side facing OUT... and slip it into the hole.  Then use a drift pin, place it on the center high spot, and give it a firm whack with a 4lb hammer.  The plug will press flat, and at the same time, expand to fill in the hole tightly.
SOME suggest putting some RTV sealant around the inside edge.  I generally don't, because the RTV will frequently degrade and then migrate into the area you're trying to keep clean and sealed, plugging up bearings or oil passages.  Some situations it's fine, so consult your doctor, ask if RTV is right for you.
BTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BTR Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2023 at 4:46am
Thank you DaveKamp.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2023 at 8:13am
I am looking at that pic and it looks like an Allen head plug in the middle of it. Am I seeing it wrong? Right under the yellow tape at leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2023 at 8:42am
Welcome to the forum
BTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BTR Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2023 at 5:35am
I bought an expansion plug and installed it like y'all said to do.  So far no leaks.  Fingers crossed.
This page was generated in 0.073 seconds.
