C Tranny?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: C Tranny?
    Posted: 19 Apr 2023 at 7:38pm
My boys project C is turning into a real project.  Discovered last night it won't stay in 3rd.  1, 2, and reverse are find.  Shove it into 3rd and it'll pop out as soon as you let off the clutch.  What are the probable issues and what are we looking at to fix it?
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2023 at 9:42pm
the dogs on the side of the gears are probably rounded off from speed shifting... grinding over many years... needs disassembled and replaced.
You can take the round cover off the right side of transmission and look inside to get an idea of damage.... the shift forks are attached to the plate so it takes some work to get it aligned and back together.... look inside if your really interested.... possible a fork is bent, or a detent ball is worn out... but that is not the most common.
Edited by steve(ill) - 19 Apr 2023 at 9:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 6:27am
The B&C transmissions are sliding gear transmissions, not a constant mesh transmission that has sliding collars with dogs. However the most likely problem is the same. Worn gears from grinding them from operator abuse. The easy fix is to swap in a good transmission. When you get yours apart, you'll most likely find worn bearings as well as rounded gears.
