3pt plow question
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: 3pt plow question
    Posted: 05 Apr 2023 at 6:38am
See pic,
What does one think the rational for having the 3pt cross shaft? mounted below the
holes for the sc coupler bar?  Hole not big enuff for requred shaft dia, or to keep with
3pt spec???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 6:58am
Measure the difference between where lift is and where you think it should have been. Raise the plow off the ground. Subtract the difference and see that the plow will be too close to the ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 6:59am
maybe it was a quick way to use existing parts ? simple,cheap, easy ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 7:07am
Seems to me to do the bar dropped down as it is requires more parts than to utilize the existing hole.  I am betting they thought the diameter of the bar had to be wider than the hole could acomodate..
Also when lookling at this, it appears the top link location relative to the plow bottoms cannot be adjusted.  My understanding there is a "sweet" spot depending on the number of botoms, width of cut.
groundhog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 7:16am
It was designed that way to be able to adjust the tilt on the tree point. Stop trying to over think it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 7:19am
hmmmm I think I follow....the fact that SC lift arms went significantly higher up than the
three point lift arms makes the difference?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 7:21am
isnt adjusting the tilt done on the tractor three point - i.e. dial up/down the lift arm?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 7:46am
2 bottom 3 pt AC plow . Been looking for one for a while. Have seen a few but rare as hens teeth
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 8:19am
For a friend I got a 3pt 3 bottom.  The wear parts are shot. Am taking the 3pt portion and putting on a 80 series two bottom snap coupler
I had all the wear parts on the  2 bottom replaced and never
really used it. Now its got the opportunity...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 8:53am
to some extent yes... But by ROTATING the cross bar, the two attachment points to the 3 point are moved FORE- AFT so you can align the rear implement to the tractor..... that beings said, i think Dr is right.... you need to crossbar LOWER so you get more LIFT out of the 3 point.
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 1:52pm
Pat, I had a 3 bottom 3 pt that was like new condition that I sold in Lathrop about 3 years ago!  And, typical, now I'm back in the market but like you looking for a 3 pt. 2 bottom
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 8:04pm
Scott , they are few and far between but just got a lead on one . Most I have seen are slat bottom plows for some reason. Also have seen a couple where they cut off a bottom. I am looking for one to put on the D15SII . I have a 3 bottom 3pt AC plow with a category 1 hitch. Just think it is a little much for the factory 3pt on the D15 . The tractor is big enough just wished Mr Allis would have put a stouter 3pt on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 8:09pm
Pat, if you get to thinking about letting the 3 bottom go, let me know as I’d give it consideration. Use behind my kubota. We could catch up at a future meet. And I agree on the stoutness if the 3 pt. Think the same with my d27
D17 Series 1
Allis B- 1939
Allis B- 1945
