D10 Hydraulic Valves
Coolharts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coolharts Quote  Post ReplyReply Direct Link To This Post Topic: D10 Hydraulic Valves
    Posted: 26 Mar 2023 at 2:59pm
My D10 finally runs:
Now onto hydraulics. I am getting a leak from the hydraulic valve body, pin hole.
I was wondering if the pin hole is really necessary? Can it be sealed? I am betting this part is still unobtanium. I would like to fix it correctly.
My luck is I blew a hose so the cylinders and lines are getting replaced.
Edited by Coolharts - 26 Mar 2023 at 4:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2023 at 3:53pm
Jon, your second and third links need help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coolharts Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2023 at 4:47pm
I couldn't link the thread for some reason.
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2023 at 5:10pm
It may have been covered in one the the posts you linked, but there are o-rings on the spools that will need to be replaced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coolharts Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2023 at 5:34pm
Are there any instructions out there on how to do this and I am assuming parts just have to be matched up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2023 at 5:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2023 at 9:54pm
Did anyone ever start making these? Tracy
