I have proof
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: I have proof
    Posted: 21 Mar 2023 at 7:48pm
That Joe was here today. We finally got to spend a little time together.
Not only that but I got to speak with Shameless on the phone as well. Feeling blessed tonight.
Look at this beauty resting comfortably in her spot.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 8:44pm
Yes, Blessed you are. Thumbs Up
Nice vice you have there...for that fact, nice set-up. Bridgeport type mill and a lathe. A person can do a lot with them if they have the skills.
 Is that all the insulation you need in the walls there?
Sure wouldn't keep the 40 below winter out here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 9:19pm
looks like you got a LIGHT on the mill !! .... How did the 3 phase work out ?
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 11:07pm
Lookin' good, Thad, great setup, but I think I may hafta bring you a larger lathe...
Sooner or later, 'yer gonna need to swing something bigger, and longer... Approve
Mebbie you should have a Steptoe shaper, too...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2023 at 4:23am
Thank you JC.
It definately needs insulation.
It was originally built as a pole barn to keep my tractors dry.
I’m slowly getting to the insulation.
I’m adding stud walls between each post and using bats on the walls.
Hoping to win the power all and spray foam the lid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2023 at 4:29am
Steve it worked out very easy.
Once you and I discovered the light had its own power source.
I ran a separate power for the light and hooked up the rotary phase converter my self. It was actually fairly easy.
The big switch on the columns is strictly foreword or reverse.
The switch on the head turns the main motor on in high range and low range.
It runs which way the reverser switch designates.
The small switch on the columns is the power feed on and off/foreword and reverse.
The mull must be running for the power feed to run.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2023 at 4:33am
Yes Dave I’ve already had a few times the lathe wasn’t big enough to turn what I needed.
I may sell this one and upgrade at some point.
Thank you for all the help along the way.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2023 at 9:07am
Sounds great all the way around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2023 at 11:08pm
was nice chatting with you too Thad! did he ever come back for his phone? prolly to busy with miss big ****s???  lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2023 at 4:50am
I had to take it to him cause he was busy.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2023 at 5:37am
Can't really think of a better reason to leave it myself
This page was generated in 0.110 seconds.
