CA RIM Recommendation
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA RIM Recommendation
    Posted: 09 Mar 2023 at 6:58pm
Hi, I'm debating on embarking onpulling my dad/grandpa's CA out of the fence row and getting it back in working order.  I find 12 inch rims available.  Are there any disadvantages to 12 inch rims?  It appears I could install 11.2 tires if I wanted to, like it has now on 10 inch rims.  But I want to go as wide as possible without impacting cultivating (or other) performance.  What is the best recommendation?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2023 at 7:03pm
does it have spin out rims on it now ?  are you staying with that, or going to a loop rim with adaptor hub ?
Edited by steve(ill) - 09 Mar 2023 at 7:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2023 at 7:05pm
Spinout, yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2023 at 7:11pm
you can buy 24 inch spin outs in 10 and 12 inch wide...... Putting a 11.2 inch tire on a 12 inch rim may be pushing the limit... WHY do you want a wide rim ?  If your going to buy 14.9 inch tires, thats different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2023 at 7:18pm
11.2 tire is 43 inch diam
12.4 tire is 46 inch diam
14.9 tire is 49 inch diam
you might be best with 10 inch rims and 12.4 inch tires .... lots of CA with that setup.
BobPaulusCentrOH View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobPaulusCentrOH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2023 at 7:23pm
I have put both 11.2 and 12.4 inch tires on 10x24 rims no problem.
14.9 x 24 would be too much for CA 10 inch wide rims.
I can't say that I have ever seen a CA with 14.9 tires.  D12 Series 3 different story.
Good Luck,
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2023 at 7:24pm
Dad complained that it got stuck in low spots all the time.  So he switched to an H.  Wanted to have the best long term options for improving the traction.  Was thinking 12.4 tires on 12 inch rim which would allow me to go wider still in the future, if needed.  I'll note that I never got stuck in low spots with it, but he can be brutal on farm equipment :(
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2023 at 9:26am
Any reason for not including 13.6?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2023 at 9:44am
no reason... you could put 13.6 on the 12 inch rims.... going to set up a little more than stock, thats all.
This page was generated in 1.191 seconds.
