170 power director
D-SERIES View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-SERIES Quote  Post ReplyReply Direct Link To This Post Topic: 170 power director
    Posted: 20 Feb 2023 at 11:24pm
Im rebuilding my 170 power director.  Looking at the price of the agco discs and aftermarket discs.  has anyone had experience with A&I products or the Alto products discs sold on ebay and actually tested them long enough to say good or bad.  wondering if its worth the money to pay the extra for factory discs or it this a you get what you pay for scenario. thanks in advance.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 5:17am
What type work u doing with Tractor
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 5:54am
Interesting. The only parts I usually replace in a D-17 (S3/S4) or 170/175 are the ramp plates and rollers. Why does yours need discs or plates ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-SERIES Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 8:36pm
My clutch discs all measure on average between .115-.118 the manual shows discs to be between .117-.123 new my measurements i will post as you can see my low clutch is shimed down to only having .030 shims in it. So im assuming the discs need replaced?
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-SERIES Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 8:43pm
Here is image of my endplates
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-SERIES Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 8:49pm
Also images of my clutch discs which i believe a couple have some warping it looks as if some of the plates almost have some rubbing on the inner centers by the splines
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-SERIES Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 9:01pm
Here is an image of the shims in the locations they were removed from which as you can see there was a .010 shims that was misplaced in the outside that needed added to the center shims. From what i read or watched they say you can only service down to .055 shim thickness on outside shim packs. As you can see my low side shim pack is at .030 so i kinda expected my clutch discs to be smoothed down more and not show much for grooving left in the fiber. The one picture of my metal disc you can see some pattern grooves from the friction discs but nothing that is super grooved or catches you finger nail when run across it. So didnt figure they needed replace and they measure same thinkness as whats stated as new plate thickness. Looking for any advice i can get on what needs replace the endplates dont show alot of wear where the rollers run on engagement but more of a wear divot on the inner lip of the where the bracket sits when engaged
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-SERIES Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 9:05pm
I dont know if phone numbers can be exchanged on here but would love to talk though this with someone with the experience
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 9:27pm
Normal wear on a clutch that has been used. Wear on the discs and plates are compensated for by short shim removal and replace the same amount back into the long center shim location. If you want all new parts, go for it. Anything warped should be replaced. If it was mine, new ramp end plates and rollers and adjust shims as required.
Edited by DrAllis - 21 Feb 2023 at 9:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-SERIES Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 10:50pm
so in your opinion do new clutch discs tend to have very much more fiber then what mine look like in the pictures.  my thing is if there is enough difference it is easier to do it now then 5 years from now and the loader it on it but i also dont want to needlessly replace parts if it wont make much difference.  i inspected the rollers for wear or flat spots and they dont show any signs of wear that i can see.  Does it look to you like the end plates are due for replacement from what you can see?  they are horrible expensive at $350 per plate or i see Allstateagparts sell a replacement for $155 which i assume are good enough quality and do you have an opinion or experience with them.  thanks and sorry for all the questions just want to make it right it was my fathers tractor and il keep it alive for the rest of my life.  one other question is is there a maximum amount of adjustment you can go on shimming these or does that not really factor in due to there still being good disc left to wear. i have heard that the .090 outside shim packs are only supposed to be adjusted down to .055 which currently on my low side clutch im already sitting at .030 and i realize new ramp plate would help with this measurement also
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 8:22am
I don't see how loader work has much to do with wear on a Power Director clutch. This isn't a "Shuttle-Clutch" tractor is it ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-SERIES Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 8:46am
NO IT IS NOT A SHUTTLE CLUTCH IM JUST SAYING ITS EASIER TO DO THE WORK NOW BEFORE I PUT THE LOADER ON AND HAVE TO REDO THE JOB IN A COUPLE YEARS. MAYBE IM JUST OVERTHINKING THE WHOLE THING. I WAS JUST CONCERNED WITH DISCS DUE TO HOW MY CLUTCH WAS ALREADY SHIMED DOWN TO .030 ON THE LOW SIDE CLUTCH WHICH I KNOW THE ENDPLATE BEING REPLACED WOULD CHANGE THAT AS WELL. I JUST WAS UNSURE HOW LOW A PERSON COULD SHIM THE LOW CLUTCH OR IF THAT DIDNT REALLY MATTER UNLESS YOUR DISCS WERE DOWN TO METAL ON METAL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 9:32am
90%+ of the time I ever have one of those clutches apart, it's because they are jumping out of high side and sometimes low side. This usually occurs with cold hydraulic oil and high engine speeds. Seldom do I ever replace anything but ramp plates, rollers and return springs. Why did you take yours apart ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-SERIES Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 10:25am
WELL I HAD A DESCENT ENOUGH LEAK FROM THE PTO ENGAGEMENT LEVER O-RING LEAKING AND WAS ANNOYING ENOUGH I WANTED TO FIX IT SI I DRAIN FLUID AND PULLED INSPECTION PLATE AND DTERMINED I WASNT GONNA BE ABLE TO REMOVE THE ROLL PIN TO GET THAT JOB DONE WITHOUT SPLITING THE TRACTOR AND I HAD A PRETTY GOOD CREEP WHEN IN GEAR BUT POWER DIRECTOR NOT ENGAGED WHICH I KNOW CAN BE COMMON MY D19 DOES THE SAME THING BUT NOT AT THIS MUCH OF A CREEP SO I FIGURED WHEN I SPLIT IT IT WAS A GOOD TIME TO LOOK OVER THE CLUTCH THE TRACTOR WAS MY FATHER AND I DONT THINK HE HAD EVER HAD ANYTHING DONE TO IT.  WHEN I SEEN THE .030 SHIM STACK ON THE LOW SIDE I DECIDE TO SPLIT THE POWER DIRECTOR APART TO INPECT THE DISCS ECPECTING TO SEE THE DICS COMPLETELY WORN OUT BUT NOT REALLY WHAT IM SEEING.  THE CLUTCH HAD BEEN SHIMMED BUT ALL THE SHIMS PUT IN THE CENTER STACK WRE SHORT SHIMS INSTEAD OF THE LONG SHIMS OTHER THEN THE ORIGINAL .025 SHIMS FROM ORIGINAL THE REST OF THEM ARE SHORT SHIMS WHICH I KNOW THEY ARE ALL SUPPOSED TO BE LONG SHIMS IN THE CENTER STACK AND MAYBE THAT IS SOME OF MY TOLERANC PROBLEM IDK IF THAT WOULD ALLOW THAT PLATE TO FLEX ENOUGH TO BE SOME OF THE PROBLEM OR NOT I JUST WANT TO MAKE IT RIGHT
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-SERIES Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 10:30am
IF THE ROLLERS NEED REPLACED I ASSUME THEY WILL SHOW WEAR OR FLAT SPOTS CORRECT?  MY ROLLERS LOOK GOOD I THOUGHT I DIDNT REALLY SEE ANY WEAR ON THEM. BUT AS YOU CAN SEE THE RAMP DO HAVE WEAR AND WASNT SURE IF THAT WAS SEVERE ENOUGH TO WORRY ABOUT OR NOT BUT NOT SEEING MUCH OTHER WEAR THINK I HAVE TWO OR THREE OF MY FIBER DISCS THAT DO HAVE A LITTLE WARP OR CUPPING THE METAL TABBED PLATES LOOK GOOD AND DONT SHOW ANY WARPING
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 10:31am
Yeah. The short shims in the center shows that whomever did the "shim job" didn't have a clue. The way your ramp plates look, I'll bet it would jump out of gear at full throttle/cold oil. New ramp plates will tighten things up some. You might find yourself adding short shims back where they cam from.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 8:52pm
Replace over center plates and rollers if they have flat spots or end pins broken off. Disks look like new. Save your money.                     MACK
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 6:08am
THIS!!!!!!
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 6:31am
Again, none of us are there looking and holding your parts, but make sure there are no driving discs or seperater plates that are warped !! Everything must be flat.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 3:27pm
We have had no issues with these parts from A&I
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 3:30pm
IF we do replace clutch plates, we use the solid center discs especially on high range.  I one uses the tractor for grain auger work - make sure it is in high or low range - not neutral as a neutral out of adjustment slips both ranges with minimum clearance on the non engaged side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-SERIES Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2023 at 6:14am
thanks for all the information. i appreciate the straight forward answer Mack and the confirmation the discs looked like new that what my measurements were telling me for the most part just wanted to make sure i wasnt missing anything
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-SERIES Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2023 at 9:09pm
So a quick update of the power director process i would say my biggest problems were not plates or end plates but the large spring pressure washer in the end plate assembly and the huge difference in the return springs and you can see my end measurement. Withe all new discs in the low side clutch my shims were .070 in the high side clutch .055 on the low side and .080 in the center very interesting to me that with all new plates and end plates that im that far away from factory new measurement of .090
This page was generated in 0.199 seconds.
