RC Dishes Pistons |
AaronSEIA
Orange Level Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2551 |
Posted: 01 Feb 2023 at 6:42pm |
Had to pull the head on my boys RC to diagnose a stuck valve. Was surprised to find dishes pistons. They are flat around the edge for maybe 1/4", then have a dish in them. Not shaped at all like an M&W or Power Crater piston. Any idea who's aftermarket piston they are and what the compression might be? AaronSEIA
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4722 |
Those are the pistons that would have been installed for a kerosene engine at the Allis factory. Are they Iron pistons? Many of the earliest pistons were iron, not aluminum. The C/R would most likely be 4.71:1 or 4.75:1.
AaronSEIA
Pistons are magnetic. Block is an RC block with a G code. Shifter is completely wore out but the sleeves have almost no ring lip at the top. AaronSEIA
Orange Level Access Joined: 12 Sep 2009 Points: 20479 |
So, it's probably been overhauled once ?? It would be interesting to run a compression test on it. Might have been engineers first attempt at Power Crater piston bowl design, except not with a flat cylinder head.
PaulB
Thanks(1)
Compression on a BE/CE engine with dished pistons would be very low. To even get a reasonable 90-100 PSI requires the piston to be flat, because of the chamber in the head and come up to (or very near) the top of the sleeve at TDC. Not an attempt at Power-Crater pistons like used in the 20l-226 engines without a chambered head.
Better compression in a BE/CE engine requires domed piston or more stroke as was designed into the replacement for the BE/CE which was the 138/149/160 which has a flat, non chambered head. Most likely with the "G" suffix suffix on the engine it was a low budget overhaul with used parts, or possibly something that dealer wanted to get rid of cheap. A kerosene engine (that would have left the factory with dished pistons) would have a "K" suffix.
Edited by PaulB - 03 Feb 2023 at 6:53am |
