Revisit Oil Seal Replacement
Ken McGregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken McGregor Quote  Post ReplyReply Direct Link To This Post Topic: Revisit Oil Seal Replacement
    Posted: 01 Feb 2023 at 11:19am
This is for the felt rear seals on the pan of a WD45. I realize that I need to split tractor for the crank seal replacement but can I replace the felt seals(2) by loosening the capscrews and taking the pan off alone? Just asking for a friend. I know about the necessary crush, etc. but am trying to save a little labour
regards,
Ken McGregor
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2023 at 3:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2023 at 5:29pm
Oil pan gasket and the ARCH gaskets (front and rear) can be changed in chassis. Rear seal halves need the engine removed to replace them.
This page was generated in 0.229 seconds.
