WD45 diesel steering
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Topic: WD45 diesel steering
    Posted: 08 Jan 2023 at 5:08pm
We have a 1955 WD45 diesel with factory power steering. We know it's obviously a 68 year old tractor but we were hoping to tighten up some of the slop in the steering. We narrowed the majority of the slop to the front bolster/worm gear area. Is there anyway of tightening up the insides to improve the quality of the steering at road speeds? Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2023 at 6:10pm
I have a couple NOS sector gears for the WC/WD/WD45 tractors available. Unfortunately no worm gears though, maybe someone else will have a NOS worm gear.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2023 at 8:25pm
Wide or narrow front?                      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2023 at 5:16pm
Wide front and the tie rods are all tight.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2023 at 8:31pm
If I’m thinking right, there is shims on the steering shaft that might take some slop out if the bearings are loose…
Someone correct me if I’m wrong…
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2023 at 4:01pm
The shims adjust the bearing preload. I don't think they will affect the gear mesh.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2023 at 4:59pm
Joe, you are correct. Shims adjust for 0 end play with free movement
