6x6
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Topic: 6x6
    Posted: 07 Jan 2023 at 12:54am
well...the 6x6 ATV i bought for the old lady.....ooooooops....I mean the loving wife, is sitting, won't run, has a Kohler V-twin OHC engine. runs on carb cleaner and starting fluid, flushed the fuel system and lines, new gas with  a little bit of HEET in it, took the fuel pump hoses off (vacuum pump) and wasn't getting much out of it, order and replaced the fuel pump, still no change. sprayed lots of carb cleaner inside and outside the carb. am affraid to take the carb off, last time I messed with a little carb, a little spring zinged out and was never found...guess it was an important one! any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2023 at 4:43am
if you can find the ID tag on the motor, it would help tremendously!Wink
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2023 at 5:30am
how about the fuel filter?
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2023 at 6:22am
If there is a fuel shutoff the needle and seat are stuck shut.  Had it happen on my generator and it didn't take long, it had sat for a little over a year without running.
If memory serves me right it's on the side of the carb.
Edited by Kansas99 - 07 Jan 2023 at 6:25am
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2023 at 7:07am
Fuel lines rotten in the tank maybe and sucking air.
Ethanol is good for that.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2023 at 7:47am
My 720, the dip tube in the tank has a hole or crack in it, I have to make sure fuel is above it. I replaced a perfectly good fuel pump also. I just ran a hose from the pump inlet to a can of gas to prove my problem.
fjdrill View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjdrill Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2023 at 9:03am
I'm with K99. electric fuel S/O, lower carb, flywheel side.  They are kinda pricy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2023 at 9:20am
me too....
the 'frugal fix' is to unscrew the 'anti dieselling valve'(B&S term), rip off the rubber, then replace.
Now get get flow 24/7 BUT the needle valve IS the shutoff.
I've done 2, cut the gas line installed a B&S shutoff
It might just need cleaning. easy to test, clean then hit with 12v and be 100% sure it MOVES...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2023 at 10:02am
good idea, this will instantly tell if you have a fuel restriction.
Clue to the shut off thingy, it has a wire or wires hooked to it.  Have a new one on order for nine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2023 at 11:05am
My Thermalarc welder was that way, had to braze the pickup tube at rust thru line and change all 'rubber' fuel lines.  V-twin Honda on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 7:53am
fuel filter replaced, the gas tank is a gravity flow out the bottom, the hoses are clear (open), replaced a few hoses, will check the needle thingy when I go back out there.
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 11:53pm
Sounds like it will be a fun toy once you get it running.  Now be honest, did you REALLY buy it for the old lady, er loving wife or for yourself?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2023 at 3:39pm
gotta be for her John....I don't fit in it!! (to chubby)
This page was generated in 0.266 seconds.
